Help! Only occurs first thing in the morning!
Buckaroo93
2003 V8 4WD Limited
When my wife starts out in the morning, within 1/4 mile or less, the ABS Skid flashes/beeps several times, goes off then the VSC TRAC, VSC OFF lights come on and stay on. When she gets to work she turns it off. When she starts it up later in the day, everything is back to normal.....until the next morning when the same thing happens. Sometimes it occurs within 300 ft of the driveway. I recently had a mechanic replace the bad rear air suspension with coils but that was about 3 weeks ago. I've driven it after she gets home and it has sat for several hours but I can not get it to do it for me. Any ideas?
2003 V8 4WD Limited
You need check codes and post results here. Most corporate-enslaved auto parts stores will check codes for free if you don't have a scanner.
Jesse1
