Help Please
Mburr
I've got condensation building up in the tail light of my 4Runner and is pooling in the bottom.
Can someone help by explaining how to pop off the stop/turn light cover so I can drain it? I'm not sure where to pull and pop it off.
THanks all
THanks all
No cover. It is all one assembly. You have a crack somewhere that moisture is getting into the housing. Check where your bulbs seat first.
Yeah, I know where the crack is and was hoping to remove the outer layer, dry it out and seal it again. But can't get that off... I hate to bite the bullet and buy a new assembly.
What are the thoughts on drilling a small hole at the bottom to drain and then fill it with a silicone?
Sure why not. Whats the worse that could happen? You buy a new tail anyhow :wink2:
I would try to fix it first too as long as it isn't noticeable.
Can you drill a small hole on the back where it could drain out of sight and not take on additional water?
Drilling might work, but why not just take the light unit out, (Remove panel inside the cargo area right behind the tail light, then two nuts and 3 clips, unit is then easily removed). Then, if you know were the crack is, you should be able to seal it from the rear of the housing......maybe? Be safe.
