Help! Trying to diagnose swaying problem
That sounds like bad rear links to me..
(just read all of the above posts saying the same thing, lol)
Thanks! I will replace them, even if it doesn't fix the issue as I am sure a lot of my suspension related components are tired. I hope it does resolve the issue though.
Seems Sonoran Steel has some great quality hardware for this.
had a similar problem.
It was so difficult to explain.
Let of the accelerator and it would "sway" left & right.
Dealer suspected fronts first since that where the problem seemed to occur
and replaced them. Same problem.
In the end, it was the real stabilizer bars and the problem went away after they were replaced.
So did you wind up replacing the front(Sway bar) and rear suspension stabilizer bar? Or did you only replace the bushings inside the bar?
seltzernator
