Help: VSC/TRAC/ABS/BRAKE lights on plus loud, continuous alarm?
My daughters 2003 V8 seems to happen intermittently and goes into limp mode for a few seconds and then self corrects. It is very scary for her. It doesnt have any codes as it self corrects and goes back to normal. I can't get a pic or video as it only lasts for a few seconds and we never know when. Anyone else has this issue with going into limp mode?
Since we are in ABS thread, get the ABS codes read. There may be pending or stored codes. Which limp mode? My '03 engine did not go into limp mode when my ABS pump failed. If the issue is intermittent ABS failure, suspect relays or fuses related to ABS. Re-seat relays and ABS module for starters. Re-seat connectors to the ABS pump assembly.
AAA membership provides towing (flat tow truck when requested) services.
The basic membership plan provides 7 miles free. The top 2 plans provides 100 miles and 200 miles respectively.
Consider signing up today. Read the fine print or talk to agent if there is a probation period before effective. You are planning a road trip and are getting ready for travel by car.
Year membership is under $100, I think.
