Help with secondary coil isolator with RAS conversion
Mikes3rdgen
Hey all, doing a RAS conversion here soon. Swapping to dobinson variable coils. Ive done some research and am under the impression that the secondary cone isloators that go inside the coils are NOT needed? if im wrong please explain.. but with that being said, what are you guys using in place of the isolator? just a trim spacer? or just metal on metal?
thanks in advance and happy holidays
Moog K160061 Coil Spring Insulator, Insulators - Amazon Canada This was all I used as I didn't feel like dishing out $150 for a set Toyota Isolators. They say the coil cones act as a bump stop but the truck already has bumpstops that hit the axle from the frame so you should be good.
Thank you! Thats what i was thinking. Id rather buy the hardware for the lower section of spring and not have to spend 190$ on the cones
BillM777
