Help with sway bar end link bushings please!
Cricoid
OK, I replaced my front and rear sway bar bushings with some polyurethane bushings...so far so good. But I've been trying for a week to figure out how to remove the end link bushings!
Here's what I'm looking at.
Do I unscrew the nut off the top of the bolt while holding the bolt stationary from below like this?
If I'm correct, then that nut is not coming off. I put the force of a thousand gods on that thing and couldn't budge it. And this is after a gallon of PB blaster soaked it. Am I doing something wrong? I'm about to say screw it, hang that bag of end link bushings in a tree and do this: :uzi:
That's correct, just add some more muscle. The lock nut is just frozen on from years of rust. If you feel comfortable with it, clean off the PB and take a micro torch to the nut and heat it up (keep a fire extinguisher near by):flamethrwoer2:.
Or...
You can take a sawzall to them and replace them with Medlinks. Contact Phil (Medic83) on 120 first to make sure he still has some left.
securedownload-2.jpg~original
Do it! :D
That's how I did mine, took the top nut off just as in your pic.
Then I think mine is just rusted to hell like the rest of the undercarriage. Would sure make working on the thing more fun if it weren't for all the rust. Snapped a bolt off doing the rear sway bar bushings and had to drill it out of the bracket. Ugh.
Would taking the wheel off and jacking the suspension help at all? I figure that would just make it worse. I think I'm going to have some end link bushings for sale.
leolediola
