Hey electrical gurus...
bofa
Thanks to a suggestion by 'Go Jaybee' I learned that with just the DRL on, the output on the dash and info display is much brighter and actually visible with my sunglasses on. So... how can I rig it so that those displays are always that bright? There must be a way.
Maybe for those standing in front of your 4R, not inside! It has been a common complaint about the std stereo, the small fonts and the inability to see the screen with polarized sunglasses. I think it was a game to see how small they could make the XM channel numbers in the corner.
bofa: Thanks for vindicating me. Apparently there are those who feel the need to contradict anyone who has less than 500 posts.;):
I guess I should have :rtfm: I'm going to try this tomorrow. Although... I'm not sure if this will help if I have something other than DRL on during the day.
bofa:
Very interesting....I thought I was the only one that read the manuals, but I totally missed that one. Seems like there was an option for the dealer to customize settings at the 1k courtesy check-up...it was on the list, but I did not fully understand what was being talked about. Oh well, I will be getting my TIS Cable soon, so I will be able to really screw things up if I want (or not) to.
Woo Hoo....almost into double digits with posts!!!!!!!!!!!
Well I tested this out and it only affects the brightness with the lights off or with only DRL on. It still dims with the other settings. Back to the electrical gurus. :sadwave:
I have this exact complaint.
If I have the lights on for safety, trails or rain / fog, but it is not night time - you cannot read the screen.
Very frustrating.
I went through the nav screen settings trying to change the brightness, but a lot of the buttons were greyed out if I remember correctly.
Maybe the techstream can unlock the settings and the dealer or the program software can adjust the brightness.
Still trying to figure it out, but not trying too hard.
wait what are you trying to do? with lights off or DRL on the display is very bright, with headlights on it dims.... so are you driving with headlights on during the day? confused as to why you would be driving with sunglasses on after sunset lol
I spent about 3 hrs last month trying to trick the dash lights into "staying bright". All my ideas were dead ends.
I'm pretty sure CAN sends a signal to the dash to dim the cluster. The radio display looks like it's dimmed by a direct link.
Turn your lights on while looking at your dash. You will notice the radio display dims immediately and then the cluster dims after a very short delay. Has to be a CAN signal IMO.
I gave up after I took the plunge and had to re-solder half a dozen wires...
Good luck- maybe I took the wrong approach!
Haha, yeah I just leave the lights on since they turn off automatically.
Turn your lights on while looking at you dash. You will notice the radio display dims immediately and then the cluster dims after a very short delay. Has to be a CAN signal IMO.
Hmm.. I wonder if this is something that could be adjusted via techstream then.
Luceann
