thorridder
sweet just ordered mine
how long did it take to get your shipping conformation?
Im about to place my order from ddm, But have a quick question ( sorry if it has been answerd in the thread)
I want hi and low beem . On the 4th question down were it says :
HID Harness - dual in , dual out.
Do I need that aswell or does that not apply -99 4runner
im glad you could answer that Clemson i got a little concerned for a sec haha. gosh DDM made what... almost $200 from this thread alone so far??
Have you ordered yours yet?
I snipped mine cause it should make them last longer i think most guys have done that here.
but here is a pic of what i did in case i ever need them back very easy mnod with no side effects
As for the Hi/LO its the same bumb so as long as you already have it on it should be warmed up. what happens is the bulb adjust from the casper shield causing it to shine at a different angle
what does that do ^^^
couldnt you just turn them off???
Yes.. and cutting that wire is one way of doing it, other's put a switch for more flexibility and others just disconnect the DRL module in the engine bay.
If I remember correctly DRL delete is different from years 96-99 and 00-02...others can verify.
How are you guys mounting the balasts? Mine dont have any ind of mounting brackets or tabs.
I guess I will fab something
It disables the DRL feature...with it connected you will have your HID's running full time shortening it's lifespan.
Quick question. What came in your kit?
All that came with my last one was the ballasts, bulbs, and four small zip ties. No tape and no instructions.
Do your bulbs have shields?
