HID kit help (DDM)
Yeah, I've seen that guide. It's pretty nice. Too bad they don't send it with the kit.
From the pictures it doesn't look like the shield covers the bulb very much. I might have to add to it.
hey guys i was reading your stuff here and it rose a couple questions for me
first with the installation guide i tried to find the 9003 H4 bulb one and i didn't see anything are all the hi/lo kits are they all just the same?
Next is it looks like you have to rig these ballast to your battery (correct me if im wrong) Right now i have a couple things rigged up to the battery now (my PIAA lights and my stereo system.) Deceptiwave you mentioned your getting a fuse box, is this something to use as an alternative to hooking all these wires to your battery?
This should work: http://www.google.com/url?sa=t&sour...ksieDg&usg=AFQjCNHubW46yStha062u2sy_vjJbKm9xQ
My positive termal is getting pretty full too. I need to find a solution.
well the 5000k looks F'en sweet in my VW R32.. so bright and id def. pure white. Compared them to my Dads Audi S8 and Id say they look Just as good. His cut off is soooooo nice though
Put mine in a few weeks back.
FYI, in order to get the bulbs to lock into the housing (if you are still using stock) I had to cut a few chips out of the 'weather cover' or in order to push the HID in all the way...you will see what I mean when you try to put it in. I zip tied the boxes to existing stuff under the hood. I also had to run the ground from the passenger side HID to the battery b/c I didn't have anything to ground it too on that side...so I just ran it back over and wire tied it with the other wires randomly going in front of the engine (watch out for the radiator fan!!..haha).
Overall the lights work well. I have been bright-lighted once and that was by a miata that was probably staring directly into them. I will post some pics next week...been swamped lately.
Also, you can download the directions off of DDM's site...super easy. Took me less than an hour to do everything...first time to do anything like this.
Disable the DRL's and when you do make sure it is the correct wire...there are 2 yellow/black wires...I mentioned it in the thread below I think.
http://www.toyota-4runner.org/3rd-gen-t4rs/70928-teach-me-oh-wise-ones-about-hids-7.html
Had the same problem- I had to run my wires over my radiator fan and taped them their/ ziptied them to a few places so they'd stay in place. Been that way for over 6 months, no problem. I was scared at 1st because I thought they sent me the wrong kit and it took me about 30 mintues to figure out how I was too run them. Too short of wires... I also had to slice open my light weather cover to fit it in there, wasn't too bad and didn't do a perfect job, yet absolutely no problems so far and wheeled through water with them too so. Seem to be great!!!
Look for the H4 install guide. pdf
I am going to get a 6 terminat Blue Sea fuse block to wire up my HIDs, IPF lights and my alarm.
The ground wire for the passenger side is too short?
hmm im actually interested in this, where do you get these things at? and your saying this is a better alternative to having a bunch of wires rigged on to your battery?
got the HID kit today. These things are huge! Everything looks good though, they feel pretty durable and it looks like a quality kit for what i paid. It didn't come with any sticky tape or zip ties so i may have to come up with something myself.
Im planning on installing it tonight or tomorrow im not sure yet. Im pretty re****ed when comes to installing stuff like this but i may figure it out
here some pics of what you get and what the H4 HI/LO kit looks like
So im assuming that the metal shield on there is the casper shield?
007-1.jpg~original
010.jpg~original
Yep. That's the shield. Thanks for the pictures.
It shouldn't be too hard to install. You will have a wire going to your battery, one or two grounds, and then plug the bulbs into the ballasts.
I'm ready to see some pictures with it installed. :p
I see what you mean now, My ebay set did NOT come with shield now after seeing it. I had people high beeming me daily on my other car.
Glad I went with ddm
I like having the extra expandability and protection of the fuse block. You can get them on amazon or at a boating supply store.
007-1.jpg~original
010.jpg~original
Well crap - mine didnt come with the plastic covers!
