HID upgrade, which one to go with?
I'm looking at swapping out the phillips 4300k bulb on my Xenon Depot XD HID kit to 5000k.
What comes included with the replacement bulb and what is involved with the install? Do I just swap out the bulb or does it come with replacement cables as well?
Is the rubber grommet the same size for each of these kits?
[MENTION=90192]2chains[/MENTION] - The grommets are a little different between the bulbs -- the ones on the Philips bulbs are slightly larger. You will get a new grommet and wiring when purchasing replacement H11 HID bulbs.
Steve
Hey 2chains, I ordered the kit from Steve, and it was an absolute breeze to install. Literally a 10 minute job. Customer service was top notch, and I'd order in a heartbeat again from xenondepot.
Ps;, I am in YYC as well ;)
[MENTION=12905]XenonDepot[/MENTION] - Steve - When is the best time purchase HID's and LED fogs in regard to pricing? I notice you all have sales periodically and being that I am very cheap i would like to save as much money as possible. I think the best sale pricing Ive seen recently was 20% off (which is GREAT) but was curious if you all ever did a huge sale during the year... I am excited to order them but I want to be patient and save some money. Thank you and i apologize for being so cheap!
[MENTION=151788]ackbar77[/MENTION] - Thank you for your feedback :)
[MENTION=128642]bronkswv[/MENTION] - lol, never apologize for saving money :) Send me a PM with what you're looking to order... I'll do my best to help you out :)
Steve
[MENTION=12905]XenonDepot[/MENTION] - Steve, I received my Phillips 4300k HID kit and the Phillips LED fogs on Saturday. Installed everything Saturday night and I am kicking myself for owning this 4Runner for 3+ years and not doing this sooner! Great Product and even better customer support. Thanks for taking time last week and calling me to answer a couple questions and getting my order placed. Ill be ordering full LED replacement Headlight and Fog-light housings for my Jeep Rubicon from you very soon!! Thanks again!!
Has anyone added a second set of projectors to their headlights? I really want hid high and low beams.
I retrofitted Lexus IS350 Bi-Xenons with a clear lens upgrade into my 2016 with OSRAM Nightbreakers, Morimoto 35W ballasts and Diode Dynamics HD Halos.
As [MENTION=51186]philsey[/MENTION] mentions, it was expensive but as a headlight snob it was totally worth it :)
Work was done by El Stig Garage here in CA.
Here's a link to a photo of it:
https://www.instagram.com/p/BOiM1sBjOXZ/
I also have the XB Fogs, they are awesome.
Below photo is low-beam only, no fogs.
NDWE9m2Dx3jpAmy4P3RD1FH-2akNBJgpAA6emY9n7g39ThcvfH5ysZAvXcpPVxIcITWSMTT4yccUGTLjBOQBOb8ZSY5I0AV8ElFLMk5HXMCQHB3c0qj7pLoiPtizWWBYUyj521LBBwQKMxzLsKMLvmzyJnidtmSUmo4DHrYy5xF4RjC9GENS_R9W2RDuvmQHfrb6sEAJrJ9N8IWrgFjH9tL77ZGddTp-8IPPyup_6dmJlxs3r78SliMQC_d7LSIft8uCFb2S7EjL8JUoMG9gCc682BAAw2UwDy9z7wdhNXUVZfytpfW0PPEaaEuoUh7v7rAIiqmTueF6XcJAIKLrv8T2lqlD20PWDy_lkuzR8LDmpxRNZiWTLlb89Po9yyHF5on_Aj1oDoHozaKl5Z1CSIbOC1YSCQRLdlyQ2lgsYA5ScG-a9ru4tj6O_aBqFTfvdjeoOXJAUwz8YdoavnUDAglpneGbB_7abrcL29mpMg4-GkLzxZYy_zP3bkhpCHMZr3MMkIJi6N0iKEmUQ9Uj6YfYrtYQ482TWicMni6smBIsVCL2LtDRCo1hvECRXFuE3L3p3t6UfBjqjrUwL3FeKBKDWsr0QqCd-T0Yw9B5R63nY0w7MT_WNsHrtlVdDBrG5qo56SKHC8AEKiwLOqRufK5omZtPv5wCShanzomYkg=w1188-h891-no
I went with the Xenon Depot xtreme in 5000k. Wanted a whiter light and be able to match other lights easier. The fogs I went with the Phillips Extreme Vision LEDs from Amazon. With Prime I received them next day!
For the DRL/Hi Beams I used the DDM tuning saber LED KIT. They give off a slight hyper flash but don't mind it much. They look much better than the yellow DRL and super bright when used as hi beams. Sorry for the crap photos, need to take some night shots.
Before
After- They match up better than what the picture shows.
With Hi Beams
Got mine installed today. 2017 4Runner Limited.
H11s from XenonDepot. They were VERY helpful with all my questions prior to install. It was a breeze. Few pics below.
Used a 1" spade drill bit to hone out the hole required for the wiring to pass through the access cover to the light housing. Smoothed the round edge with a round wood file. Allowed the rubber grommet fit super snug.
To help with aiming after the install, used painter's tape to mark where the old lights hit the wall in our garage, marked the floor to ensure truck would be in the same spot.
Pulled the battery completely out to allow for easy access to driver's side.
Difference on the road is night and day.
Of note, my 4Runner does not have the 8mm nut at the rear of the light housing to adjust beam height. Rather, it has a "gator tooth" style system that accepts a phillips head screw driver to adjust the height located on top of the housing. Small hole for access though the plastic cover between the radiator and bumper.
Pic below.
Hope it helps.
Pic below.
Hope it helps.
Thanks for the feedback and taking the time to post pics of your process. Glad to hear you're liking the results :D
Danny
Pic below.
Hope it helps.
Which bulb temp did you go with?
MaximussK
