Great stuff here. Thanks. Will look into scangauge. You have any recommendations?
I bought OBDLink MX+. It took awhile to set up 4 dashboards that gives me continuous real time data on my iPhone 8+ to the following parameters: 2 transmission fluid temps, coolant temp, battery voltage, 4 catalyst temps, 2 oxygen sensor voltages, 2 long term fuel trims, 2 short term fuel trims, total number of DTCs, number of emission related DTCs, total number of all cylinders misfire count, number of trouble codes, evaporator fin thermistor temp, and 4 tire pressures.
I have scanned for DTCs and none were found. I haven't tried the data log, monitor or mapping features. I will load OBDLink software on my laptop when the weather is cooler.
When launching the app, one has to select a connection to a particular system, such as Network A (engine, steering, airbag, a/c, driveline, etc), Tire Pres Monitor, Network F (vehicle body), Telematics, Immobiliser, and Occupant Detection. I haven't tried using the last 4 features. Note, each network is separate, therefore, when looking at tire pressures, one cannot simultaneously view engine data because each network has a different control unit.
Overall, I like how the information is displayed and I wanted something easy to use. BlueDriver is another one to consider. Google search BlueDriver vs OBDLink MX+.
