///AIRDAM
page 199 in my manual
"tire pressure warning reset"
when initializing the system, the present tire inflation pressure is stored as a standard. The tire pressure warning system determines decreased air pressure by comparing the present and the standard tire inflation. when you change the set tire inflation pressure, it is necessary to initialize the tire pressure warning system.
"to initialize the tire pressure warning system perform the following"
-park vehicle
-adjust all installed tires and spare accordingly
-turn engine switch to the "on" position
-push and hold the tire pressure warning reset switch untill the tire pressure warning light blinks slowly 3 times
-wait a few minutes with the engine switch "on" and then turn the engine switch off
then it goes on about a bunch of things you should not do, and what to do if it does not perform properly ect.
this allows me to set my base pressure at something other than 32 psi.
-park vehicle
