Sentinelist
Granted, I could track these down individually and get to troubleshooting, but thought I'd run this concerning list by you guys first. This is a 2005 V6 2WD. Oh hi, btw. I'm new. I brought beer. :cheers:
Scanned using an Innova scanner with Toyota logic- already tried erasing all DTCs, ran the truck hard on the highway, brought it back, shut it down, then scanned it again- these keep popping up. But it runs great, no CELs, no complaints, found after a preventative check this evening I did over the whole truck before my mother-in-law departs on a trip to Missouri in the morning... at least she has roadside assistance!... :rofl: But I care. I do! Really behaves fine despite all this. She's had the truck for 2 years now, zero issues. I haven't run codes on it until now (again, tried clearing these, multiple times). Very curious.
P0300- Toyota Readiness Random Misfire Detected (OK, I may need to change the spark plugs first)
P0011- Toyota Readiness Intake Camshaft Position Timing - Over - Advanced (Bank 1)
P0012- Toyota Readiness Intake Camshaft Position Timing - Over - Retarded (Bank 1)
P0021- Toyota Readiness Intake Camshaft Position Timing - Over - Advanced (Bank 2)
P0022- Toyota Readiness Intake Camshaft Position Timing - Over - Retarded (Bank 2)
P0100- Toyota Readiness Mass or Volume Air Flow Circuit
P0102- Toyota Readiness Mass or Volume Air Flow Circuit Low Input
P0103- Toyota Readiness Mass or Volume Air Flow Circuit High Input
P0125- Toyota Readiness Insufficient Coolant Temp For Closed Loop Fuel Control
P0420- Toyota Readiness Catalyst System Efficiency Below Threshold (Bank 1)
P0430- Toyota Readiness Catalyst System Efficiency Below Threshold (Bank 2)
P0500- Toyota Readiness Vehicle Speed Sensor A
P0705- Toyota Readiness Transmission Range Sensor Circuit (PRNDL Input)
P0717- Toyota Readiness Turbine/Input Shaft Speed Sensor Circuit No Signal
P0722- Toyota Readiness Output Shaft Speed Sensor Circuit No Signal
P0748- Toyota Readiness Pressure Control Solenoid A Electrical
So, where's the reset button for starters?
Of note, her battery is hardly holding 12V and was found tonight at 11.7V but doesn't have an issue cranking yet- solid 13.7V while running, alternator good. I'm replacing it as soon as she gets back next week. So some of these may be voltage related (may replace batt and then rescan). Your thoughts? Thanks, folks.
