Homemade....Let's see what you've made
That looks like a pretty involved project. It gives the rest of us some inspiration to follow through on a detailed job to its completion! I love the touch of class it adds to the truck too.
Wait till you see my fenders when I get done with them :smokin:
Might even start a build thread more focused on function than form
I made this in-dash obd2 pid reader from an Arduino and my old oem radio chassis. Not sure what I was thinking... Seems like something a crazy person would build.
This deserves more attention. Crazy? Absolutely. But very, very cool.
Sent from my Nexus 9 using Tapatalk
I completely removed all parts of the factory rack...only kept the screws. This where I started the whole project - laying down a couple flat pieces of steel cut to the length of the old mounts. Drilled holes to line up with the screw holes and built from there.
Is that the Sparkfun OBDII board? I did a similar build and we might've used almost exactly the same parts:
How does that LED display hold up in sunlight? Mine doesn't do very well in daylight. Want to rebuild it with a better display someday... wish there were more commodity OLEDs available already. :(
My rack is 98"x50" i stood it up on 6 legs that i bolted through the roof just inside the drip rail bodyline on the roof. Rear legs are about 6 inches from the back of the roof, middle legs are pretty centered, then the front legs are on each side of the sunroof.
Something I have been working on for a little while now, not done yet but I think you get the idea. Next I need to fill all the spaces... :usa2:
I just made some rear window screens for warm weather camping in the back of the 4Runner.
They simply slide over the top of the door frame and a magnetic strip seals them closed on the bottom. They roll up real neatly while on the road, too.
They could be a little neater, but I didn't feel like spending too much time on them and since I work at a clothing company, I might bring them into the office to have our sample makers re-sew them up nice and strong.
Yeah, It's a OBD2 Sparkfun board. First I tried to make a CAN BUS shield work, but failed.
The display is a Parallax serial 2x16 backlit lcd. It is easy to see in daylight/sunshine.
I also wired up a ftdi breakout board. One of the toggles is three position so I can select between SparkfunOBD2-arduino (for normal operation), SparkfunOBD2 isolated (for uploading new code to the Arduino) and SparkfunOBD2-ftdi (for direct serial communication).
That is an awesome idea
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Thanks. I've seen a few other versions of this, with magnets all the way around, but the B pillar isn't metal on 4th gens and storing a magnetic rectangular square sounded like a real pain. My version rolls right up!
Ah, I was wondering what the little one was there for. Neat setup! Every time I have to plug in the computer and remember arcane serial port commands, I regret not building in some faceplate controls like you have. MkII is going to have something to reset codes at the very least.
As featured under the heading of " my 4 dollar window screen"
Basically it's a piece of gutter screen cut so that it fits into the groove of the window on the top side and has a channel that the window slides into one the bottom side.
[MENTION=88597]MyHigh[/MENTION], did you post this elsewhere? I love the idea and was hoping that I could do it on my tailgate window, but of course, it's not square, so the sides would still be open...
Spod
I cant justify the cost of a actual SPOD but the SPOD product is a great idea so I made my own version.
It has been working for about a month now with no issues at all. I have around $100 in it. All of my switched accessories run through this. It sure cleaned up the wire mess under the dash.
Not in the picture is a cover I made from some fake leather so it does not get wet when I hose off the motor compartment.
My two year old son made this, again he's two and said I am a robot beep boo beep
