how big of a tire can i fit on my 2nd gen?
924runnerSR5
was wondering if i can fit 33x10.5x15 bfg mud terrain km2 on a stock 2nd gen 4runner. no lift kit nothing. will they just not fit or will they just rub a little with a little modding can fix. help is appreciated
ty much
33s
I've got BFG 33 all terrain on my 95 with no lift and love it. Just had to hack about 3" off the front corner wheel well. Its what you see as my avatar.
A 33x10.50 tire can in some cases fit on a stock height vehicle, provided you are using the stock rims as well. The KM2 has relatively large shoulder tread blocks and will more than likely require you to lift the 4Runner slightly, or trim areas that rub. The most common place to rub on the front end is the mud flap - which is easily removed - and on a seam that runs inside of the inner fender well. The seam can be folded over flat so that there is a minute amount more clearance, but the better bet is to adjust your torsion bars (if only seeking tire clearance and not overly concerned with droop travel and/or ride quality) or install ball joint spacers and longer shocks.
I am a firm believer in raising your vehicle as little as possible to get away with the tire size you intend to run. With that said, mount a set of 33x10.50r15s to your rims, bolt the rims to the truck and watch for rubbing. If the rubbing is minimal and only under certain (rare) circumstances, you may not need to do anything. If the rubbing occurs slightly along the seam inside the fender well under suspension compression, then look into bending the seam flat.* If the tires rub fairly regularly, then you will need to raise the front end via adjusting the torsion bars (22mm wrench, lots of solvent, and about 12 turns per inch of adjustment) or installing the aforementioned ball joint spacers.
If you have 4.56 gearing right now, you will probably be okay with 33x10.50 tires, although 4.88 gearing is optimal. If you have 4.10 or 4.30 gears you may want to consider a re-gear, or swapping 3rd members with someone looking for your ratio (and who has the 4.88s you desire).
I'm actually looking to install a set of 33x10.50r15 KM2s on my stock rims in the coming weeks. I went ahead and got 1.5" ball joint spacers, longer shocks and and a differential drop kit just to make sure I am covered. So, why would I advocate lifting as little as possible, then turn around and buy a 1.5" lift kit for my truck, even though it may not be needed after flattening the seam and/or minor trimming? Kind of makes me sound hypocritical, no? My reason is simple: install the ball joint spacers for more travel, trim as needed, flatten the seam and then let some tension out of the torsion bars so they ride nice and soft (and subsequently will allow decent flex off road). When all is said and done I hope to have 33" tires on stock rims, at or near stock ride height with 1.5" more suspension travel, a softer ride and close to stock CV axle angles. Your goal may vary.
*link to flattening the seam in the fender well: Pinch Weld and new 33x10.5 tsl's - YotaTech Forums
I've always thought and been told 33x10.50s fit stock with minor pinch weld hammering and trimming of the front valance. 12.50's is where problems are enountered.
33's on my 1st gen rub on the sway bar at full lock , ball joint spacer and 15x8 rims in the future
misc2010010.jpg~original
Then 31's should suit you just fine, and not require lower gearing to get the power back.
That's a very good point. People forget that bigger tires are going to cause a loss of MPG and power if you don't regear. 31's are a good compromise.
Great info, as someone who bought a project truck to take off road to actually use the mods I mean to do, youre explaination of what and why was really appreciated!
I had 33's on mine and wheeled it with minor rubbing. As stated above i did trim the corner of my fenders though In the last pic i think you can see where it was trimed
ty much
I have a set of 33x10.50 BFG AT2 tires on stock wheels and suspension on mine. No rubbing at all, but I think this also has to do with how much your suspension is sagging. As far as I know my torsion bars are not cranked. That being said I have yet to compress the suspension enough to see if it tucks properly.
Sweet truck!
265/70/17 translates to 31.5" x 10", which should fit height and width wise. But, it's hard to say if the 17" rim will work in place of the normal 15".
The question is, why do you want to go from a 15" rim to a 17" rim? If this is a street queen and you like the look of a larger rim better, then fine. However, if it's for trail use, stay with the smaller rim. More rubber and less metal on the wheels is absolutely better for off-road performance, especially handling rocks. (Look at the rim to tire ratio on your local earthmover for a good example of what serious off-road tires vs. rims should look like.)
Agreed. Not to mention much cheaper for 15" tires.
Sent from my Moto G Play using Tapatalk
I think the tire & wheel setup you have is perfect on your rig. jmho
Honestly the stock wheels are pretty badass on their own. Toyota even used specific lug nuts on a lot of their vehicles to ensure the wheels wouldn't sit uneven
RennSport2UZ
