how to disable rear defrost
Same fuses on a 2007. Just to be clear, the indicated thing your pulling is the relay, not the fuse.
I don't believe mine has the mirror defog, so just pulling that relay should be sufficient. When you hit the defog button, you here it click. After removing it, no click.
Started the car, and no CEL, so it's not multiport fuel injection.
Thank you, relay.
I am a dummy.
I dont have the side mirror defog either, didn't think of that.
Anyone got a picture of the specific plug to unplug in the rear hatch to disable the rear defroster and leave intact the heater mirrors?
It the only wires connect to the hatch glass so it shouldn't be hard to spot, there are 2 wire side by side, click on the following link below (which I post earlier in this topic post number 11) and there are 2 photos of the wires and connectors only but doesn't show the glass, but as I said they're the only wires connected to the glass.
https://static.nhtsa.gov/odi/tsbs/2017/MC-10131801-9999.pdf
Perfect Thank you!
Whether it's heat from arcing or increased resistance from corrosion, the root cause is almost certainly water either way. If you slather the whole area in some dielectric grease you should be fine for years. And/or just add comprehensive insurance to your policy for $50/yr or whatever it may be. I was sure wishing I had that coverage when a tree fell on my car worth over $5k and the homeowners/renters didn't cover it, have carried it since.
After seeing numerous posts on Facebook and in forums about the rear window shattering, I went ahead and disconnected the defrost heating connections. There are two connections as mentioned above, on the passenger side of the window (farthest to the passenger side) It helps if you roll the window down about half way so you can access it easier. I pulled on each tab, first one was easy, second one I needed to really work off. After removing the connections, I taped them up and zip tied them to the wire closest to it, and then put everything back together. I didn’t notice any corrosion or browning on the metal tabs, but the plugs looked pretty old. I’m up in Michigan and it’s likely that this shattering could happen due to the severe cold/un-even dispersing of the defrost heat on the window, so i feel a bit more at ease now! Hope this helps!
To add even more Context and some pictures... Here we go
*Step 0: roll down rear window about 1/4 to 1/2 down
Step 1: Remove inside tailgate 10mm screw on pull handle and remove the handle
Step 2 remove another plastic access panel for a place to pull from
Step 3: Firmly but carefully pull out clips for interior tailgate cover trim removal of entire cover trim is not needed as shown in the picture
step 4: gently remove moisture barrier from right side, leaving the sticky stuff intact to be reused
step 5: locate the 2 wires plugged into metal prongs on the glass in the right corner
step 6: remove plugs and zip tie to wire harness out of the way
step 7: reapply moisture barrier and put everything back together
Total time: 2 minutes and 30 seconds
Value: Never need to worry about glass exploding
Heated mirrors still work
Thank you [MENTION=149207]AuSeeker[/MENTION] and [MENTION=621669]mi4Runner313[/MENTION]
Hopefully someone is still looking at this thread. I've got a 2007 4runner sport V6 4WD. 236K Miles. My rear glass shattered this past summerdue to the defroster problem. Yup, was scary! When I had the glass replaced at All Star Glass, i asked them not to connect the electrical connectors for the defrost. Now it's winter, and I wouldn't mind using the defrost. Does anyone know if it was the factory glass that was defective, or if it is the electrical system that's defective? Of course I'm wondering if I cleaned up the connectors and connected them to the new glass, is this likely to happen again? I'm pretty sure the replacement glass they put in was pilkington brand glass.
According to Toyota they redesigned the glass, it was the electrical connection point overheating that caused the glass to shatter.
I think it was also noted that it was happening as the glass and array setup were getting old. I recall some threads about not using it if the connector area started looking corroded or green/gray. Personally, I think the need for it outweighs the possibility of it breaking, at least in my area.
Thundro
