Rock_Rat
Senior Member
If this is your first time replacing front pads or doing your own brakes, then this thread is for you. Since these are on a 231 TBU then you're already proficient.
Changing out front brake pads is an inexpensive preventive maintenance measure. If overlooked, what should only cost you about $32 for new pads could end up costing you a fortune in unnecessary repairs.
It was time to change out my front brake pads. They were getting down to less than a ¼” of pad left yet they still weren’t hitting the wear indicator, so it was time. There’s no hard and fast mileage for brake pad changes as each driver has a driving style all of their own.
Since it was just the front pads, it should only take about an hour total, 30 minutes per side with everything in place and ready to go.
Tools/Materials Needed
DISCLAIMER: Prior to beginning this job, thoroughly inspect your rotors for cracks, discoloration from heat, grease, and/or uneven wear. If in question, then perhaps you may need to perform a complete brake job.
Step One
*If you’re using a breaker bar and socket, loosen, but DO NOT REMOVE the lug nuts while the vehicle is on the ground
Step Two
Step Three
NOTE: If the pistons do not move freely you may have to remove the caliper.
Step Four
Total time to complete this job should be less than an hour if you have everything prepared in advance.
As always, whether you change just the pads, rotors, or both you need to "bed" them in correctly.
First and foremost, it's important to engage your parking brake, chock your wheels, then raise your rig safely and minimize any potential failure. Placing your wheel and tire underneath your LCA is for added security.
Replacing pads on the TBU is extremely easy. Remove the two "R" clips on the caliper pins and discard. Remove the caliper pins and discard the "W" clip.
A pair of needle nose pliers should do the trick
Now use a "C" clamp and steadily and evenly tighten the pad against the caliper piston. Alternate between the top and the bottom until the pad can easily be removed. If the piston doesn't move freely, stop and investigate.
Use the worn pad as a leveraging "pry-bar" applying pressure between the piston and the rotor. Only use the bonded side of the pad next to the rotor. To "flatten" both pistons on one side, you may have to use both pads at the same time.
When ready you can use some brake cleaner around the exposed caliper and rotor but do not spray any on the rubber boots. I chose not to clean my calipers. Apply a liberal amount of synthetic caliper grease on the pads and the pins. Install.
Ensure the wear indicator is on top. It needs to be placed in such a way as to go with the rotation of the tire. It doesn't matter whether it's on the inside or the outside.
Well, here it is a 20 or 30 minute job per side. I would recommend you install the pins from the outside towards the inside. The caliper is made in such a way as to "protect" the caliper retainer clips. IMHO I don't really think it matters.
- Jack
- Jack stand
- Impact wrench with socket
- Torque Wrench that goes to 85’ Lbs
- “C” Clamp
- Needle nose Pliers
- 21mm Socket
- Synthetic Caliper grease
- New Brake Pads - I went with the Wagner Thermo Quiet QC976. They've been great on my rig so far.
Step One
- Put on your parking brake
- Chock your rear wheels with a large stone or 4x4 etc.
- Jack up your rig and ensure your jack is safely locked*
- If using a Hi-lift - use it correctly
- Place a jack stand underneath
- Finally, when you're wheel is removed, slide it underneath your LCA as an extra level of safety
Step Two
- Remove two caliper pin “R” retainer clips and discard
- Remove the two pins
- Remove the "W" pin and discard
Step Three
- Using a “C” clamp gently tighten the pad against the brake piston
- Alternate between top and bottom until you can remove the pad
- Follow the same procedure on the other side until the pad is free
Step Four
- Apply synthetic caliper grease on the metal surface of the pad and install on one side
- Using the two removed pads, work BOTH pistons on the other side until flush or until you can install the second pad
- Install the second pad, pins with synthetic lube, retainer clips and “W” clip
