4Runner4Leon
Senior Member
What follows is my attempt at the most comprehensive set of wiring instructions for swapping a ‘99+ center dash bezel into a ’97-98. The wiring aspects of this swap include rewiring the ECT switch, the hazard switch, the back window switch, the defogger switch, the backlight illumination, and the newly added power outlets. I just completed this swap, swapping an ’02 bezel into my ’97 Limited.
I’ve read numerous threads about the swap, but with the loss of many Photobucket links in other posts, a lot of the needed info was difficult to recreate. So I’ll try to lay out all the wiring details of this conversion, complete with wiring diagrams, photos, and tips and tricks. That way you won’t just see me say “do this”, you’ll see the supporting data behind having to “do this”. The goal is for this to become a one-stop shop for anyone contemplating this conversion, without the need to research numerous posts with missing links, or confusing information or instructions. I won’t detail the mechanical aspects of this swap, such as what parts to remove, how to get to the switches, etc, because that part is fairly straightforward. We’ll just focus on the wiring.
To give credit where credit is due, here are some sources I looked at that helped me get started:
http://www.toyota-4runner.org/2695579-post275.html
http://www.toyota-4runner.org/3rd-gen-t4rs/230792-tyler-james-incs-oem-97-limited.html
http://www.toyota-4runner.org/3rd-g...nner-digital-clock-revived-tooth-surgery.html
https://www.yotatech.com/forums/f2/those-who-want-put-99-center-dash-bezel-43660/index2.html
http://www.toyota-4runner.org/3rd-gen-t4rs/114346-how-99-center-dash-conversion-wiring.html
http://www.toyota-4runner.org/3rd-gen-t4rs/234735-dash-center-bezel-questions.html
https://www.youtube.com/watch?v=N2JopkvWd0s&feature=youtu.be
Before we start, here are the wiring color codes that I will use, same as Toyota’s and most other wiring conventions.
B - Black
W - White
R - Red
G - Green
L - Blue
O - Orange
LG - Light Green
If there is a tracer (i.e. a wire with one main color with a tracer of another color), I’ll use the letter for the main color first, and the letter for the tracer color second, i.e. R-B means red wire with a black tracer.
So without a further ado, let’s get started.
What parts to get from the ‘99+ donor.
- Dash bezel, including the combination switch which includes the ECT, defogger, and back window switches
- Y-shaped duct behind bezel
- Hazard switch, its connector, and harness (the connector and harness are not a must, but helpful as I’ll discuss below)
- C23 white connector attaching to the back of the donor combination switch, along with as much of the harness as you can get
- Power outlets at the bottom of the bezel and connectors and wiring harnesses attached to them
Below are some photos of what I got from the donor.
Bezel and Y-duct:
You can’t see the Y-duct because it’s behind the bezel, but you definitely want to get it, because the ’97 duct will not line up with the ‘99+ vents.
Combination Switch:
Combination Switch Harnesses:
In the harness photo, the C23 connector is on the lower left, and the hazard connector is smack in the middle. The orange connector is not needed, nor is the clock connector in lower center, since you’ll be reusing your old clock and connector (the clocks are identical).
Power Outlets and Harnesses:
I peeled the wood off the ’99 bezel and painted it. I first tried silver, but didn’t like how it looked in my truck, so I hit it again with some satin trim black paint:
Preparing the donor harnesses.
First I separated the harnesses from each other:
Then removed the jacket from the C23 harness to expose the wires:
Before we leave the topic of donor parts, let’s talk about the C23 connector a little more (you’ll be getting very cozy with the C23 connector, might as well get to know it well). Below is a schematic of the C23 connector, and how its 10 terminals fit into the ’99 wiring system:
It has 2 terminals for illumination, 3 terminals for the back window, 2 terminals for the rear defogger switch, 2 terminals for rear defogger indicator bulb, and one terminal for ECT; 10 terminals total. We’ll keep referring back to this when figuring out how to wire all the switches.
Preparing your ‘97 for the swap.
As I said earlier, I won’t discuss how to remove the bezel and get to the wires; that’s covered fairly well in other threads, and is really straightforward. Just pull up and remove the console rear trim piece, pull up and remove the shifter trim piece, pull off and remove the AC/heater face panel and remove the two screws behind it, and then pull off the bezel. You’ll have some bulbs and connectors to disconnect along the way, so take good notes.
Then reroute the ECT and back window harnesses from the console area up behind the bezel and to the center opening near the AC vents and clock. To do that, you’ll need to open up the harness with those wires, because they are tied together with other wires that need to stay in place (for parking brake indicator and 4WD switch). Looking below, it’s the harness along the left side of the console – you’ll need to cut the zip ties and remove some of the taping holding all the wires together:
Now separate the ECT, back window, and security wires from the other wires that will be staying:
I then retaped the wires to be relocated to protect them behind the bezel:
Then I routed them up to the opening above the heater/vent controls. Here they are smack in the middle and out of focus – white 6 pin connector is the back window, black 4 pin connector on its right is the ECT:
I initially routed the security microphone and light up there as well (the two smaller harnesses right above the words “anti theft” on the radio), but later moved them to the knockout on left side of the dash:
Now you are ready to start rewiring!
B - Black
W - White
R - Red
G - Green
L - Blue
O - Orange
LG - Light Green
Bezel and Y-duct:
Combination Switch:
