I can barely get my hood closed even when it is slammed pretty hard
4x4toyz
There seems to be no easy adjustments on it and it is ridiculous how hard you have to slam it to get it to shut.
Is this a common thing with 4runners? Mine is a 97. :confused:
There are 2 things tha can cause this:
1.. Your hood or latch is out of adjustment (You will have to adjust it either at the latch or pin. If it is way off, check the whole hood alignment)
2.. Your release machanism is becoming seized. This could be any part of the latch or even the cable.
Most likely it is either or even both of these.
Try some penetrating grease on the latch and pin. You can also try looking at the latch for tell tale signs that the Pin is not striking where it should (i.e. Dents and Scrape Marks)
Cheers,
