I did this ___________ for $100 or less to my 4runner
DEKA3
Registered User, A.K.A. "elias"
So, I was on another forum this morning, and saw this thread: I did this _____________ to my rig for less than $100. So i thought that it might be interesting to post this on here as well.
Basically, any mods that you have done to your truck that were $100 or less.
I have a feeling [MENTION=65614]Antman[/MENTION] will be a regular on here! :wave:
[MENTION=65614]Antman[/MENTION].....Always a bargain...which ain't a damn thing the matter with that!!
New LED "spot" lights installed into the handles of the rear lift gate....$30.00
I have been looking to do this. Was it plug and play or did you need to mod the lights at all?
It was all plug and play. I wasn't sure it would be when the tech at superbrightleds.com suggested the canbus style tower for my courtesy lighting under the mirrors, but it all worked perfectly.
If you use the standard wedge base bulb it has an 8500K rating and is way blue.
Next is adding the dome light into the cargo area mod!!
I flushed the powersteering and replaced all the seals in the pump for less then $100.
I replaced my starter contacts for $33.
I made a solid Walnut shift knob for $7.
Got these bad boys at pepboys the other day......
On a serious note, I had the front windows matched to the rears. Also picked up a set of oem all weather mats for about $70.
I haven't yet, but am considering adding the factory mudgaurds ($49.95 online) as the tires love to spray water up the sides and rear bumper.... still looking at pics to determine if I'm ok with the look.
Here are some:
Fiamm Horns
Removed front air dam
TE rims (net was a gain because I bought them for less than I sold my LE rims for)
Stubby antenna
Interior LED bulbs in stock locations
License Plate LEDs
LED strips in cargo area
Engine Compartment Lighting Mod
Relocated 4-pin trailer light hookup
K&N air filter
I just counted 28 mods in my thread that cost under 100 bucks. Thrifty!:nerd:
All listed in the table of contents (with links )
Too much to post here!
delislerebecca
