Making progress...
For the last couple weeks I've been trying to find a welder to do the install on my sliders and perform a frame endcap mod. The first guy I contacted wanted 4 hours @ $85/hr to do both... ummm.... ok. I found another guy who's a retired navy welder to do both for 3.5 hours @ $50/hr.
Finally, I got to thinking about it and I remembered my boss builds and sells these from scratch. (That's a LS6 powered sandrail, full handbuilt tube chassis, 18" of suspension travel, fuel injected, power steering, 5.29 gearing, a $7000 transmission, on and on and on)
So I got my arse in gear and started getting the sliders ready for today. I got them set up on a tarp in the garage and rubbed them down with acetone to remove the penetrating oil that Stubbs covers them with prior to shipping... all pretty and ready for primer.....
The chemicals... Acetone, then primer, then paint, then plasti-dip on the bottom to protect against rock chips....
Masked the feet and primered 'em....
All painted up... I had to leave the plasti-dip on the bottoms until later to allow the paint sufficient drying time...
Got to El Jefe's house and took some measurements... I decided I wanted them mounted as high as possible, so I got to grinding the pinch welds... This allows some extra room for the legs and lets you mount them about 1/2" higher up on the frame (after I ground down the pinch weld I used Toyota touch up paint to paint the bare metal in order to prevent rust)....
The head honcho broke out the 220v Miller mig welder and went to work on the passenger side, then we repeated the whole process for the driver's side... Measure 18 times... weld once. The fitting, marking, measuring, and measuring again took multitudes more time than the actual welding.
Finally... the finished product....
Oh yeah... When we got done, he took my wife and I out for a ride in the sandrail... holy crapbaskets batman!!! 550hp... 2100lbs... major giggle factor. I couldn't wipe the smile off my face. Even with 2wd that thing would have embarrased my 4Runner on some of the terrain we covered. Doing nearly 100mph on deep sand up a dry arroyo while the rear end is barely getting traction is simply insane. It went straight up steep sand hills, the supsension absorbed 12" bumps in the road and barely moved you in your seat, it was crazy. I guess that's what you get out of a purpose built toy that costs 5x what my 4runner cost me.
The XRC8 got delivered by the brown truck, so I'm going to clock the winch, put it in on the bumper along with the IPF lights, pre-wire everything and head back over in a couple weeks to do the frame endcap mod and install the ARB/winch/lights all in one fell swoop.
