charlier180
Interesting perception as the specs do not indicate any significant changes in physical size.
(The ground clearance for the 2009 should be 9.1in)
Thanks for posting that actual specs. I remember seeing the specs for the 2010 a while ago and being grateful that Toyota had not ballooned the size of the 4Runner with the new generation like they had done with other models in their lineup.
Interesting how the perception of the size of the 2010 4Runner ("it's Bigger") is nowhere close to the reality that it remains virtually unchanged in size. Reminds me of how companies that make food products change the packing of their products to give the illusion of more product in the container when they keep the size the same or reduce the size. In the case of the 2010 4Runner, they did add 275 hundred pounds of curb weight so I guess technically it is Bigger than the 4th generation.
BTW, maybe the original poster should talk to his daughter about swapping 4Runners? Then again, if she has had her 4th Gen for a while, that might be easier said than done.
