I may be joining the family...pics
Looks good! The painted frame always scares me. Makes me afraid they are hiding something but it looks good here...
the door color is a little off from certain angles, but for the age it was acceptable. I'm kinda kicking my self a little bit for purchasing it, but my wife and kids really like it. I like how it rides too, no rattling in the suspension at all when going over bumps and stuff.
One of the belt squeals when starting it and the drivetrain is a little hummy around 50 mph on or off the gas. I've noticed a few of you have this issue.
I was under the car again looking at the frame and it looks like the paint was there for awhile, can't be too sure but it looks solid. I took a screwdriver and was poking around. To be sure, I'm going to have a mechanic look at it again.
It's missing the trunk cover. Other than that interior is very clean.
Also I noticed the rubber moulding on one of the passenger windows is missing a connecting piece of trim about a half inch wide. Not sure where I can get this.
Should I just replace all fluids to be safe? He did say he changed oil but the oil looked a little dark to me. Also he mentioned the timing belt was done but not sure if he actually did it. Is it easy to verify?
Right now I want that vibration/humming noise fixed. Oh it needs two tires too.
What fixes should I prioritize first guys?
Were you able to get any service records at a?
I'm in the same boat as you and I did :
Lower ball joints
Water pump
Timing belt
Fuel and air filter
Plugs and wires
... look into replacing the radiator as well.... preventative measures for strawberry milkshake.
