I want to replace all 5 window weatherstrip on my 1996 T4R SR5. Part numbers help!
Benski
Member
I want to replace my old, shrunken, brittle window weatherstrip on all 5 windows. I'm talking about the pieces that are on the top of the door where your arm would rest with an open window. I can't seem to find the numbers for the rear door windows. Also, could someone recommend an online place to buy them? Thanks!
I did this awhile back and ordered them from Toyota of Newnan at a great price. Here are the part numbers:
68161-35010 (Front Right)
68163-35010 (Right Rear)
68164-35010 (Left Rear)
68290-35020 (TailGate)
Do you have any before and afters by chance?
Sorry man, I did not take any before and after pics. I have two more part numbers:
Driver’s Door Exterior “Belt” Weatherstrip (68162-35010)
Passenger’s Door Exterior "Belt" Weatherstrip (67861-35040)
If you go to Toyota of Newnan | New & Used Toyota Dealer | Located in Newnan, GA and click on "order parts" link, then put in a few of these part numbers, it will bring you to the drawings of the parts from the Toyota parts manual. (I have always dealt with "Gary" or "Quita" and they have OUSTANDING service and prices and NO, I don;t work for them! Just double check and make sure these are right before you order them, regardless from where you get them. One thing I had to change was the "interior belt trim" on the driver's side. Over the years, the "felt" that rubbed up against the window had worn down and when I rolled the window down, it would drag the trim down into the door. (The glass was "catching" on the bare rubber of the trim) I replaced this and it works like new. (You do have to take off the door panel to replace this piece)
Good luck!
On the last two part numbers you listed (your 2nd post in this thread), you specified that they were exterior - are these all exterior as well?
Also, did you have to remove the mirrors to replace the strips on the front doors?
Good luck!
Do I need to pull the interior panel to replace the strip on the hatch? Mine is cracked to bits.
I don't know right now. I have ordered the parts and will get back to you when I find out.
My part numbers for my 96 were:
68161-35010 Weatherstrip FR
68162-35010 " " FL
68163-35010 Weatherstrip RR
68164-35010 " " RL
68290-35020 Weatherstrip Assy (rear gate)
Getting ready to order these parts, just wanted to clarify something in case anyone else is doing the same. The part number you listed above is for a seal lower down on the door - not on the glass:
Can you take pics? Thanks.
Before/after pics added.
If you're asking about the exterior trim, no.
Replaced all 5 exterior weatherstrip pieces this morning. Super easy, just snap off/clean/snap on. Removal of any panels or mirrors not required.
I ordered the parts from Camelback, $130.69 plus shipping/handling.
The old ones were very stiff and brittle, and the felt on the inside was very worn (last pic is of the hatch trim - it was the worst).
I ordered the parts and then looked at where the "clips" were on them so I knew where to remove the old ones. They are located between on the narrower parts of the stripping where the doors come together.
Deno91
