ICON stage 1 and XREAS question
MONST4R
If I install just the Icon stage 1 front coilovers what will happen to the XREAS oil lines going into the front shock? Do the Icon coilovers come with something to capp off the lines? I have All Pro rear 2" lift springs I can install easily by myself and am planning to use the XREAS rear shocks for the time being.
It is my understanding that you either have to have all of the XREAS, or none of it. If you want ICON front CO's you need to take out the whole XREAS setup, and get some separate rear shock to go with those springs.
The XREAS is a completely interconnected and pressurized system. You can't take off one part and leave the rest. If you disconnect one part at the shock not using the disconnects for the system you will get XREAS fluid everywhere. It just won't work. I want confirmation from the heavy hitters on here, but I think thats right.
Jang is correct. It's all or nothing with xreas. You can leave the lines and canister on the truck. My lines are still on the truck but I do plan on taking everything xreas off since I am no longer using the xreas system. The Icon system does not include any caps.
That sounds more logical and I kind of had a feeling it was like that but just thought I'd ask. If I were to install just lift springs on the stock setup would that be okay? Situation is that I'm currently trying to do this on a budget. I have OME 3" and 2" All Pro coils from a buddy already and would like to address some rubbing issues in the front tires.
Kaliram
