Installijng my stage 1 lift in the shop right now and I'm not sure where the cylinder looking spacer things go. There's 4 of them and the instructions don't mention anything about them. Anyone know? About two inches tall, one inch in diameter. Stainless steel finish.
Sounds like the front coilover spacers. If that is in fact the parts they are spacers for the bottom bolt of the coilovers. There should two different sizes, as far as I can remember the larger one go toward the front and the smaller toward the back.
Picture of the part would help.
Diff drop pieces?
Sorry guys, I didn't have a way to upload pictures from my cell phone, but they are not the front coilover spacers. Those are much shorter. I'll take pictures soon. I finished the install after about 8 hours of work and then I drove it home (shop was closing). As I was driving home, there was something cyclicly grinding on the front left wheel. It almost sounds like a dragging brake but it wasn't pulling in either direction.
Still not sure what those parts are, but I kept them for when I do figure out what they are for. The mechanic on shift couldn't figure out what they were either.
One problem we did run into though was that one of the lugs on the front left rotor sheared as we were reinstalling the tire. Sigh, guess I'll take it in to the dealership to see if that is covered under warranty. The saga continues, but I'm too tired to go dig out parts and take pictures. They'll be up tomorrow.
Hope the noise is not your sway bar hitting your coilovers. Do you have KDSS? If so, this would not be the problem. The normal sway bar is the only one that needs to be spaced. If it is not, it will contact the coilovers and mark them up pretty good.
I do not have KDSS. It was definitely something that had to do with the rotation of the tires though because it happened in a rhythm that depended on how fast I was going.
I would recommend going to a different shop. It sounds like they could not install your kit properly and cross threaded a lugnut while installing your tires.
The noise you are hearing that coincide eith tire rotation is most likely the brake dust shield. It probably was bent during the reinstallation of the front coil overs.
Get some pics of your "extra" parts so we can help you identify them.
