Idles good...but stalls when I push the throttle
nogard
My truck idles good. But when I hit the gas it will just stall out. I can start it right back up. It will idle, but if I touch the gas at all it will stall again.
Any ideas? What should I check first? I was thinking it could be the throttle position sensor?
Mine does the same thing almost, idles fine (really low in my opinion) and then she boggs right down on acceleration off the line then kicks up. Mine is a clogged fuel filter,not sure bout urs
My 92 did that , too. However, it was more intermittent-- sometimes it would take off just fine,, others,, it wouild buck and jerk like a wild horse. Turned out to be a fuel pump ( NOT cheap ) and the cause was -------- seems the last owner never changed the fuel filter,, which caused the pump to eventually go bad.
Mike
Fixed it
1993 Toyota truck V6
Bad water sensor next to #1 cylender
Sending bad signals to ECU making engine go banans.
Part #89422-35010
my 95 4Runner sputters and makes a pop sound
The vehicle is hesitating between 10 mph to about 30 mph and it will not go any faster, then I start hearing this popping noise in the engine bay (like a back fire) but if you pump the gas pedal it will speed up and the noise stops but will kinda sputter a little while driving. It has not ever died or anything while stopped. It will idle great, I have replaced air filter, wires, plugs and the fuel filter. also got a new maf sensor connector. we checked the maf sesnor working fine. truck recently got new heads installed with orignial Toyota parts. we have had this truck for 18-19 years first time it does this. the truck did at one point get a complete overhaul too about 5 years ago. this only started happening after we installed new heads, injectors&wires, and new knock sesnor hareness. dont know what else to do, but last option try my best to find a OB1 code reader or someone that has one :Cry:. Thank you
Persimmoncreek-farmer
