If you HATE crankshaft bolts.
mmarzluf
Did the timing belt, water pump, brakes, etc on our 2001 4Runner yesterday. I've been wrenching quite a few years and have done complete tear downs on Supras, Celicas, couple hondas etc so doing the timing belt wasn't a question of IF I would do it or take it to the dealership. I just knew that when the time came I would do it.
Anyway... I HATE the bolt on Crankshaft Pulleys. After I finally got this one off (using a pin in the pulley and a 24" extension bar through a hole in the frame cross member and a 4' long cheater bar on my breaker bar) I did the work and put everything back together. Course... by this time the pin I had in the pulley had had just about all it was willing to take and began to bend when I was torquing the bolt. I got it to 80 Ft/Lb and left it for now.
Ok... long speech just to get to this part I found. I have one that I use for Hondas, but didn't realize they sold one for our engine (until now). It's a spanner type wrench head probably very similar to what the Toyota techs use. You attach it to the pulley using the pins, then attach a socket wrench breaker bar to it with the square hole. Lock that against a frame rail or the ground and you're golden. No more chain wrenches slipping, bumping the starter, etc. you'll still need a long cheater bar on your breaker bar for the bolt, but at least you're sure the pulley isn't moving. I ordered one to help me get this bolt into spec and I'm sure I'll use it again. Actually, my dad will probably use it next for his 01 Tundra.
So... here's the link. I didn't see anyone talking about these when I was searching so I hope this isn't old news. Maybe at least someone in the middle of a wrench job can use the info. Kind of pricy but if it's decent quality, is priceless when you're trying to get that bolt off and on.
SP 64400|SP 64400|SCH64400|Schley 64400
ya i made my own useing the info from 4x4 wire and i got the crank bolt loose with a old school 1/2 mac impact at 120psi
IMG_1845.jpg~original
appreciate the link/visuals
We did this on our MR2 a few months back and built our own- out of wood- but it was destroyed in the remounting process.
Here is what it looked like before we destroyed it... if only we had metal fab skills and equipment.
Elton- that is a nice one you built.
I would think some enterprising soul could build 6 or 8 of these and make some coin selling em for way less than $55. The pulley sizes are somewhat universal are they not?
On the Mr2 the pulley bolt is a 17mm and we could not budge it with any air powered impact wrench. 1/2 inch breaker bar with a 4 foot jack handle finally busted the sucker loose.
Has anyone tried a pry bar on the torque converter? According to the Hanes manual that is what you can do if you don't have the SST
