Independent use of Fog Light Mod
did it!.. thanks everyone for your time and input, also to JA for the great write up..
I installed nokya 2500k in fogs and in highs too. Looks great!
Now all I need are independent high beams.....and for lows not to flash when lights are off and i flash my highs.....
Did part #2 only
Better late than never! Glad to hear it worked out okay.
First of all, a big thanks to J.A. for your amazingly precise and helpful write-ups. I did the full-time 12V/115V mod almost two years ago and the fog light mod today.
Because I couldn't think of a use case for using the fog lights without low- or high-beams, I did part #2 only. Works great, and the whole job took only about 15 min.
One observation: The steering column lower trim cover has a couple of tiny tabs on the upper front edge, facing the driver. To ensure a correct fit when replacing the cover, these need to go inside/behind the lower edge of the upper trim cover.
I was able to think of a couple of use cases after all, so I performed part #1 today:
  • Frequent: The salsa red color is hard to see during the day, especially when it's cloudy, even with DLR. Now I can use the fog lights on their own, thereby increasing the longevity of the low beams.
  • Infrequent: In very dense fog, one might have better visibility without the low beams.
Alright guys...super noob question. I was just looking at the fuse box but I had no idea what was what....I was expecting things to be labeled but it didnt seem like the were.
Is there some master diagram in the manual that you are all referencing or something?
Inside the lid.
where to tap
I have 04 limited and everything is set for this mod, except there is no room to use the 25A seat header fuse with an add a tap, as the wire hits the closest relay so there is not room. Searched every other fuse that has enough room and they are ALL constant on, not ingition activated. Any other spots within that fuse box, or is there another add a circuit that has the wire in a different direction?
Anyone use the seat fuse with a limited?
I did on on my '03 Limited and yes it was a very tight fit. Just a little creative routing and just brute force i got it to fit just fine. I was afraid I was going to break something but so far it has held up fine. Sorry but I am still a moron and can't figure out how to post pics yet...
Thanks Ruthven. I followed your advice and decided to add some force. REALLY tight fit and the wire right at the block is now bent a hard 90 degrees, but it went in and works, so nothing broke. Thanks again. Headlights are nearly useless in heavy snowfall trying to get off a mountain (don't ask how I know). Fogs only should work great.
I would just keep an eye on it (I do). I was nervous at first that it wouldn't work just like you but I figured hey, how much can go wrong. The parts are cheap enough to replace if they broke. I just wouldn't move them unless I hd to just in case. Glad it worked out for you. Wish it ws a little neater but ya gotta go what you gotta do. Did you do the stage two of the mod? That part is really simple. I forget if you need a male blade connector for that or not. I noticed if it is loose if you give the end a very slight bend it fits nice and tightly...
ok fog light mod experts....
check my logic here
2019 Electrical schematic attached
Looking at the 2019 diagram we can see that there is still an AND gate that only allows the fog light to receive power when
1) ECU PIN14 is at ground closing the TAIL relay
(AKA ECU senses that the Parking light or Headlights are powered on and then puts pin 14 at ground)
AND
2) ECU PIN 13 is at ground
AKA ECU senses that the fog light switch is the closed position.
Option 1)
Wire the pin on the FR FOG relay Coil that original goes to ECU PIN13 directly to the Fog light switch on the Switched ground side.
By using a relay tap on the relay pin and running a single wire through the main grommet on the fire wall to the fog light switch.
This would
Still allow one to control fog light on or off when the head lights are on likewise fogs would stay on even in hibeam mode.
You would still loose dash light indicator of fog light on/off
Option 2 the simplest MOD...MAYBE)
Wire FR FOG relay coil pin 13 directly to TAIL relay coil pin 14.
This would.
1) Have Fog lights come on and stay on if PARKING lights/or head lights are on regardless of hi/low beam position
2) believe this would result in a situation if you are running AUTO lights that DRLs would still work with Fogs being off while in DRL mode
3) fogs would auto illuminate if in AUTO the ECU decides to turn on headlights.
4) fog light switch would not control fog lights AKA fogs are controlled by headlight switch.
PROBLEM is ( motor off so one can hear relays close)
Sounds like the the tail relay ( TOWING TAIL marked relay) is in the under the hood fuse box; which would make sense since diagram shows 12+power coming in off of a junction connected to the alternator.
AND THE FRFOG RELAY is located behind the DASH.... :(
There is the diagram of the wire setup to make this work to have independent fog lights /retain dash indicator/ retain auto lights/ retain auto off...
Reminder this setup requires that at least the parking lights to be switched to on
This is NOT FOG light on at any time.
To find the correct wires I used a test probe to find the +12V switched coming from the dimmer dial. ( blue doubled dashed line)
and the same probe to figure out the wire coming out of the ECU that is the power supply to the fog lights ( dashed red line)
I guess I’m a moron too
Hey guys,
I’m struggling with part 2 of this mod. I didn’t do part one as I just want these for Off road usage while the lights are on. I made a mess of the wiring and clipped wires when I should t have and now am in a jam... my headlights and turn signals work but not my fogs and my headlights don’t auto shutoff now.... any help would be much appreciated.
I’m at a loss as where to go from here...
-CW
I did this fog light mod a couple of years ago, but never took pics.
More recently, I added a second (third?) set of fog lights where ditch lights usually go.
The first pic shows all the lights on, DRLs off. The second pic shows just the OEM fogs and the DRLs on, low/high beams both off. My two sets of aftermarket fogs are wired together, and only work when the headlights are on. The PIAA offroad/white driving lights on the roof aren’t connected yet, but I have all the wiring/switches ready to go. That’s my next project after I get rid of all the surface rust on the chassis/undercarriage.
REE
