Initial Maintenance for a Used 4Runner
BunMaster
I wrote this up as a reply to another member's post and it got me thinking. Am I missing anything? I picked up a used 4Runner and it had an average service record. I wanted to set the truck's maintenance history to ground zero so I did everything I could think of.
This is for a 2006 V6 4WD 4Runner.
List includes:
1) Engine (Crank) Oil (Mobil 1 5W30 Synthetic)
2) Grease Driveshaft Zerks (Mobil 1 Grease, Pink/Red in color)
3) Front Differential (Mobil 1 75W90 w/ Limited Slip Additive)
4) Transfer Case (Same as above)
5) Rear Differential (Same as above)
6) Transmission Fluid Drain/Fill (OEM Toyota WS ATF)
7) Coolant Drain/Fill (OEM Toyota Super Long Life Coolant)
Other maintenance items:
1) Spark Plugs (OEM Toyota)
2) Air Filter (OEM Toyota)
3) MAF Clean
4) Throttle Body Clean
5) Transmission Fluid (Valve Body) Filter Change
6) Valve Cover Gaskets (L/R) Change
7) Chevron Techron Fuel System Cleaner
8) PCV Valve Change
9) Bilstein 5100 Struts/Shocks (Ok fine. Not really maintenance but a sweet upgrade.)
At the moment the only other things I can think of are to do a few more drain fills of the transmission/coolant, brake fluid flush (with SS brake line upgrade), and power steering flush.
What else would you guys do for maintenance?
Crookedcat
