Any reason why injectors from a 97 wouldn't work on a 99 engine? I know the connectors are identical.
I believe I read the spray pattern is the only thing that changed (later style are better).
Sent from my SM-N975U using Tapatalk
As long as you replace all of them at the same time you should be okay. Mixing and matching injectors is when issues start.Any reason why injectors from a 97 wouldn't work on a 99 engine? I know the connectors are identical.
I did some searching on some parts vendor sites and it turns out the PN for a 97 injector is the exact same as the injector for a 99 (23209-79095) so they should work.
I was thinking I should replace the O rings also while I'm at it but yikes, almost $4 a piece and you need 12. Those are some expensive O rings. (PN 90301-07001). I'm for sure going to replace the aluminum crush washers (PN 90430-12026 qty 6).
Crush washers for what?
You do not need to take apart the fuel rail to replace injectors.
My Build and Repair Thread shows rebuilding them yourself. It’s easy.
So if I do need to swap injectors, I can leave the fuel rail hooked up to the fuel line and just pull the injectors out?
If so, than I'll do it that way.
EDIT: can you link your build and repair thread? I can't find it.
Replacing the o-rings is not optional. You'll see when you remove the old ones, they will be crushed and formed to the contour of the injector (and brittle). If you try and re-use them they are very likely to leak.
Since it's related to the subject matter, here's a video Y'all can use to swap out your injectors.
<iframe width="560" height="315" src="https://www.youtube.com/embed/N-lhZIWOkyU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
