Input on tire choices
I went with the 285/70R/17 so I expect they may slide bit in the rain but overall they should be great. I got them for about $245/tire which wasn't too bad.
they should be fine until they wear down past the "sipes" (not reall sipes but they act as a water channel) i had zero problems with mine in any weather or terrain, granted yours are a little bit wider. you should still have zero problems if your vehicle is aligned properly and you are running correct tire pressure.
Good to know, the alignment seems like it should be in good shape. I also added light racing UCAs to keep the alignment spot on with my new set-up.
