Installing aftermarket speakers in 4runner
I dont have the dimensions handy, but I have infinity kappa speakers all around. The fronts fit just fine with the included adapter ring (not a spacer, just to align the screw pattern), but on the back I had to use MDF to make my own adapters.
If there are any crossovers, just be warned that they are a pain to mount in these doors, as there is not much space available within the door panel. I literally just remounted all my speakers last night after doing some door sound deadening and new wiring for an amp, and its a tight squeeze.
your Kappa Speakers, This ring you mention, is a ring that comes with the speakers? are you talking about the component set?
I've heard a lot of people recommend to run new wiring for the speakers, and although I haven't done it yet, I would to. Especially since you have an aftermarket head unit it should be pretty simple and pretty cheap.
The stock wiring is very thin guage.
I have Pioneer 6 3/4 in the front & 5 1/4 in the back. Look for speakers with a shallow mounting depth & you wont have an issue.
I'm looking to do another budget SQ build, so im picky to an extent. I ordered some kappa for the front and rear
Like others have said, the fronts are pretty straight forward. I installed JL Audio C2s all around. 6.5s in the front and 5.25s in the rear. I used these (PVC Speaker Adapters - CNC Machined - In Stock or Custom Made) for the rears. They didn't provide enough clearance for the windows to roll all the way down, so I used the grilles that came with the speakers as a "spacer". Worked perfectly!!
I have C2's in my 01 Accord EX Coupe, 6.5 in the front & 6x9's in the rear. With the JL 6 channel amp & W2 10" sub...that system rocks!:guitar3:
Resurrect
Hi,
Hate to resurrect an old thread, but I've looked here and in Yotatech and can't seem to find an answer.
I took off the door panel to look at my front speaker yesterday. The driver's side speaker isn't working, though the tweeter seems fine. A few questions.
I took out the four screws surrounding the speakers in that gold plate. The speaker didn't want to pull straight out. Is there a trick I'm missing?
I've noticed the entire thing is on some kind of assembly. When people say a new speaker set should be plug and play, do they mean the new speaker goes into the old assembly? Or do I need to pull the entire assembly off?
Last question. Before I go out and get a new set of speakers, I want to isolate why the bottom speaker isn't working. I guess I can buy a new set and plug it in and that answers the question, but before I do that, can I use the voltmeter to measure incoming current or resistance and see if the connection from speaker back to head unit is OK? Does the fact the tweeter is working mean that the problem is inside the speaker and not the wiring? I only see a current and a ground going into the entire component setup, so that would seem to suggest the wiring to the head unit is fine.
I'm making some big guesses here. I know my way around a wrench, but wiring and electronics are a new area for me.
Appreciate the response, but looking for a solution for the front speakers. Is there an adapter for that as well? do I need to remove the entire housing?
Sorry for reviving a 2 month old thread, but just wondering if you ever got your problem fixed. If not, like what a bunch of other posters have said, go here, PVC Speaker Adapters - CNC Machined - In Stock or Custom Made. I purchased a pair of these a few weeks ago w/ a pair of 1/4" spacers to go along w/ the adapters. The adapters are the same size and shape as the original stock speaker housings and will fit 6.5" speakers. I purchased the spacers because my speakers depth was to big and was hitting the window rail. Just an FYI, with the 1/4" spacers, my speakers were still hitting the window rail and I should have purchased the 1/2" spacers instead. What my installer did was use foam tape to give it that extra spacing I needed to clear the rail. I couldn't be happier.
I posted some pics on this forum of my install. Here is the page where you can find it if you have any questions on how it looks like installed.
http://www.toyota-4runner.org/engin...s/228663-need-help-tweeter-replacement-2.html
And you can check this page too to see how it looks like installed in other 4runner models.
4Runner Speaker Installations - speakerinstallationphotos
Like I said, I couldn't be happier w/ the purchase of the speaker adapters. Oh and btw, the speakers I purchased were the NVX VSP65Kit from Sonic Electronix. If you're unfamiliar w/ the depth of your speakers, go see if Sonic sells the same speakers that you purchased and compare it to the mounting depth of the NVXVSP65Kit component speakers. That should give you a rough estimate on the size of spacers you will need to mount and install your speakers.
MaximussK
