Installing some lights..Need a switch
I like the look of the Scion switch. Does it fit the slot in our T4R's?
Yep, the FJ unit is way expensive.
I use those scion type rocker switch, to make it fit, either grind the hole bigger or grind the switch down, i chose to grind the switch, use a table grinder and grind all sides to make it work, its a tight fit.
I use a pair of these: TRD sparks fj cruiser fog light switches
Only $43 per switch and they fit in factory slots with no modification needed.
IMG_0411.jpg~original
alsayner
