Instrument cluster
Anyone know if the 06-09 instrument cluster is direct bolt on in 03-05? Sr5 v6 4x4
I'm pretty sure that it's not for a 2003/2004, not sure on the 2005, this is because the turn signal lights on the dash are in different location, early 4th gens had them at the top and later models had them at the bottom, the signal lights were partially obscured by the top of the steering wheel and sometimes hard to see them, especially if you're a tall person, I also think the warning lights are located bit different as well but I could be wrong on this point, also on 2003/2004 the V6s had the 4 speed transmission so there's no 5th gear indicator on the dash display, the V8s however did come with the 5 speed and had a different dash display for the 5th gear, so there's 2 different dash displays for 2003 and 2004, in 2005 both the V6 and V8 came with the 5 speed transmission.
AndiGarage
