intake manifold vacuum tube question
lordhowe
I replaced the valve cover gaskets (1992 V6 5 speed) and after removing the intake manifold i accidentally pulled off the vacume lines that goes into the intake manifold without labeling it.
there are a total of 6 small vacuum tubes that's next to the EGR valve. each tube has a number (1 through 6) labled on them.
can someone provide a pictures?
thanks!!
I replaced the valve cover gaskets and after removing the intake manifold i accidentally pulled off the vacume lines that goes into the intake manifold without labeling it.
thanks!!
I'm guessing you have a v6 t4r...what year is it? I do not have the book for the v6 but, I'm sure someone will chime in soon...Good luck:)
it is a v6 4runner with the 5 speed manual tranny. i actually have the manual but have no idea which section to look at. I just need some guidance from someone that has a little more intuition at PDF manuals than me.
thanks!
I looked at my Haynes manual too and I can't find a pic:shrug:
Lift the hood and look for a label with a vacuum line schismatic. Most times there is one on the underside of the hood.
ian2328
