Integrated key remotes?
2003V8LTD
Guys, do they make any keys with integrated remotes, like zillions of other cars have? I get a little irritated having the separate key and remote. I wish it was like my old Subaru where the remote buttons are the head of the key itself. Does such a thing exist for our cars?
The above listing is the same key I used. I programmed it myself and got the key cut at a locksmith. Everything works. The rear hatch button rolls the window down.
It's good to hear that it worked for you. I'm thinking of buying one as well and ditching the old remote.
the switchblade keys will stick out alot.
i gave that up and use another key remote combo, aslong the remote was compatible with the stock keyless, i had to take apart the switch blade remote and use that transponder chip to the combo. it works, sometimes i dont need to use my full alarm system. it still roll the window down.
Here is a picture.
I have a switchblade style that I programmed myself as well. I like it way better. Sure it sticks out more than the factory key but it's not in the way of anything.
Sent from my KB2007 using Tapatalk
+1
It does stick out but it's out of the way and no bother at all.
It feels heavy and good quality.
One thing though is it's very easy to keep hitting that panic button by accident. I ended up opening it up and removing the little switch/button on the inside thus eliminating the issue altogether.
Can you use the rear hatch button to open the rear window?
this one doesn't have the aux button, it's just a blank spot w/no button. but I wasn't too concerned with that. I just wanted an extra key that I could use when wheeling that wouldn't have the extra fob swinging around knocking on the dash, haha. #firstworldproblems
J.
fair enough! I wonder if the other key fobs can be used for the rear window. But to be fair, I don't use the key fob to lower the rear window that often anyways. Mostly just to show others that I have the ability to do so!
This one works perfectly on my 2003 limited. Home Depot cut the key for free, I programmed myself with the door open close/lock unlock method that can be found here on the forum. The panic button is pretty solid and I think I've maybe set it off only once or twice and I've had it for almost two years now. Oh and the tailgate button rolls down the rear window too.
Upgraded FLIP KEY REMOTE FOR TOYOTA HYQ12BBX DOT CHIP KEYLESS ENTRY ALARM FOB | eBay
I also got these stickers for it that complete the look:
NEW TOYOTA 2pcs 14mm Key Fob Emblem 3M Sticker Decal Logo Remote Badge FREE SHIP | eBay
Sent from my Pixel 3 XL using Tapatalk
