Interest in Custom built 4th gen V8 4.7 Doug Thorley Headers
Would you like the DT headers to have a Highflow catalytic converter?
  • Hell no! Open and loud.
    Votes: 35 9.1%
  • Yes, I would like to be legal.
    Votes: 283 73.9%
  • I don't care either way as long as I get them!
    Votes: 65 17.0%
  • Total voters
    383
What year is your truck? Mine doesn't rub at all (vvti V8). I'd contact Doug Thorley.
Special sale right now. Ends aug 4th.
There are two versions of headers, 03-04 v8 and 05-09. There shouldn't be any rubbing except if you're lifted. If you've lifted there's a small bolt you can replace on the steering column with a flush head to fix it.
Ends Aug 4th! V8 4th gens are known to get a leaky cracked header and start making a ticking sound. These new headers fix that problem, add abotu 2-3 more MPG and aprox 35 HP gain. New Toyota headers are DOUBLE the price. Get in while you can.
Doug Thorley 03-04 headers
Doug Thorley 05-09 headers
Also, the Gibson catback, which pairs great with these headers.
Gibson 4th Gen exhaust
I can do any and all DT headers at a deal, not just these, just call or text 717-319-2100 for anymore questions.
o2 Sensors
I just wanted to reiterate how bad Doug Thorley messed up the o2 sensor holes. I just had to remove my o2 sensors and install a spacer and its almost impossible. In fact it was impossible on the driver side. With that said anyone who purchases these in the future should ask them if they have repositioned the o2 sensor hole. (mine was 2003 non vvti version). I have pictures in previous post who I did the install. So frustrating.
Nope
Any Truth to DT adding Cats to The Headers and Make it a True Bolt On?
My Response is No from DT Directly...
Currently we are not looking to add Cats to these headers, our current
design will remain the only option we have for some time to come.
I have spacers in my rear 02's and had no issues getting them in.
Wanted to update this. I have 3 sets of 05-09 in stock, and 5 sets of 03-04 in stock. Then they are gone, it's will take until mid April to get more back in.
There are two versions of these headers, 03-04 v8 and 05-09. There shouldn't be any rubbing except if you're lifted. Now, if you are you've lifted there's a small bolt you can replace on the steering column with a flush head to fix it.
For those that don't know, V8 4th gens are known to make a ticking sound from a leaky cracked factory header. These new headers fix that problem, add about 2-3 more MPG and a ton more HP. New Toyota headers are DOUBLE the price. Get in while you can.
I also have the magnaflow high flow cats that will work with these, and I can do any and all DT headers, not just these, just call or text 717-319-2100 for anymore questions, to order, etc.
I have the Gibson from you on my 2007 V8. And have the DT headers awaiting install. Do you have a link for the correct cats?
You have to cut the cats off the stock manifold and weld them onto the headers. Its a bit tricky as the flanges need to be set right. I screwed one up on mine and ended up cutting the opposite flange off and rewelding it rather than removing the headers.
I also polished the cats before reinstalling to make them look shiny!
Cool. On the cats, call me to order, or text me and I can send a custom link to order. They aren't on the site.
The reason why most replace the cats is you have to cut the factory ones off anyway, and new ones will floe even better.
Found this in another thread, clean...
Cats
What about the cats? I know that my 05 V-8 has four. I've read where some guys remove the primary cats all together? What about the O2 sensors. Thanks
URD makes an O2 simulator that tricks the computer into thinking the cats are functioning properly even if they aren't there.
The pic just above are my headers with primary cats removed. I had to add multiple O2 sensor spacers on the rear O2 sensors to get no faults, been running a year now with no issues. No need for expensive simulator unless you're trying to fool a visual inspection.
Quick question on gaskets for the DT headers. I know the headers come with gaskets but they seem kind of cheap, so I purchased a new set of OEM gaskets. Is it preferred one over the other? Any experience with this would be appreciated since I'll be getting them installed Friday.
I used the ones that came with the headers. Just make sure not to bend and damage them.
Got ya and Just to confirm the O2 spacers need to be run on the Y-Pipe in order not to throw any codes?
Depends on your setup. I ran Magnaflow Hi-Flow cats as primary and deleted the second cats. I put spacers in my rear 02's. Are they needed because I still have cats? Not sure. When I have time I'm going to remove the spacers and try without them to see if I get a code.
Well currently I'll be running DT headers, HFCs, and stock Y-Pipe. I will eventually be swapping out for a URD Y-Pipe.
leolediola
