wfo9
I don't really believe this story 100%, but I thought I would share it just to add to the folklore of these engines.
A friend of mine recently borrowed another friends FJ. The one he borrowed was a very early 2007 built in 2006. He proceeds to ask me if there is anyway his FJ (2008) can be programmed to be as powerful as the 2007. I told him there is no aftermarket way to program a Toyota ECU, but this is where the story gets interesting.
Both of these FJs are 100% stock automatics as far as the motor/tranny goes. Other than that they are both fully built with bumpers, winch, lift, snorkels... and the 2007 is actually on 35s with stock gearing.
He continues on about how much more powerful this 2007 is then his. He claims it gets ~24mpg and has gobs of tq around 2k RPM and up. The whole time I'm thinking it must have a super charger LOL.
He proceeds to tell me that this 2007 FJ has the original programming from Toyota before all the torque management was put in to save the rear ends. The owner then shows up and proceeds to tell me that the original FJs all came AND WERE RATED with 100+RWTQ,HP, but early adopters and test revealed that the rear diff was extremely weak, so they turned down the power via the ECU. Later, they found the weak component in the diff and fixed it, but never went back to the original calibration.
The story goes on that someone took a copy of this version of the ECU and flashed it into a Tacoma. The gains were supposedly amazing.
I have a pretty decent background in tuning. So I tried to rationalize this story with them. I said it was possible that the newer ECU had more aggressive tq management, but that this would most likely only be felt around shifts and the peak tq RPM range of the motor. I also figured the throttle mapping could be totally different making the newer model feel like you have to mash the throttle much harder to get the same response (5th gen owners are very familiar with this BS) But, they both insisted it was way more than that and that the 2007 also got about 2x the MPG. The MPG difference is something that simply can't be explained as a calibration issue IMHO.
I went on to tell them that I thought there was probably a problem with the 2008 (like a clogged cat) or something. Again, they claimed the 07 was different than any other FJ (and these guys have driven quite a few).
Anyway, it's just a story supporting how dialed back the ECU might really be.... I'm not sure how much of it I really believe...perceptions are just that.. reality with data is something completely different. (although, they did claim they calculated and compared the mpg on a few long overland trips)
Also, please don't respond to this thread by insulting my friends.... They were just giving me their first hand experiences. .
