Iphone 4s pairing problems.
huskernation
So I have the new iPhone from verizon. I have nav. with my 4runner.
I have paired the phone without trouble. I had no trouble transferring the contacts.
Now when I dial out, it dials out of the phone, but it doesn't connect to the sound system and I have to use the phone to talk (not hands free). My blackberry would work seamlessly.
I have already disconnected and reconnected (with the same issue).
Any suggestions?
Thanks in advance (I did do a search and couldn't find a solution that worked).
You aren't plugging up with the USB cord as well are you?
Also, when you say transfer... Do you mean you're actually able to send contact(s) from the iPhone to the truck? From what I read you just have to manually reenter each number to the truck's phonebook. Would be nice if it could just use the phones contact list.
I have a 2011 with nav and iPhone 4s I also switched from blackberry your phone is pairs correctly next time you call out when your on the all there will be 6 buttons on the screen of the phone the top right one is labeled audio source push that button it will bring up a list select the top one for the nav system after you do this it will probably remember the setting mine did. In response to the other poster yes with the factory nav you can just Bluetooth transfer your contacts into the nav. Also it doesn't matter if you plug the USB in at the same time hands free will still work normal you can also use Bluetooth to send I pod music and pandora from your phone to the navi then you don't need to use the USB at all I do this and just use a normal charger since Toyota located the USB conveniently in the glove box.
you can transfer the entire address/phone book via BT with the Toyota Nav unit.
I have a 2010 with nav. not sure if there is a software update for the Nav, but mine isn't doing what you describe.
I can also pair with BT audio, and it does the same thing. I can control the iPhone with nav and steering wheel, but no audio from the truck sound system.
No, not using usb port, only BT to pair.
the button is on the phone not the nav. top right corner of the phone only during a call. for the bluetooth have you tried going into the audio menu on the nave and registering the new audio player, you have to do this even after pairing is done.
so my iPhone (sorry I didn't read your post carefully enough) doesn't have that option on the screen. When I call out, the button I see is speaker phone, the other are mute, keypad, add call, face time and contacts. It shows BT icon in top of phone. I am verizon, not sure if it is different or not? I am not having any luck with the pairing.
again thanks for any help.
It should be th top right of the 6 - Audio Source. You should get a little menu with several choices, and hopefully, one of them is your head unit.
HTH
The me labeled speaker phone changes to say audio source when the phone is paired to a Bluetooth device. If it does not say that it isn't pairs to the navi. Out of curiosity your old phone isn't sitting In the car is it. The nag system pairs to the oldest device first if more than one are present at the same time.
Try next time your in the car push setup, phone, manage phone And look for your I phone on the list if it isn't there delete all phones from the nav And all pairs from the phone and start over.
Found the problem. After removing and reconnecting about 10 times, We decided to try my wife's Iphone 4s that we got at the same time, no issue's. Pairs without trouble and handsfree works fine.
So now......Is it an Apple issue or a Verizon issue? Wife has same exact same phone and service. I hate calling verizon (or God forbid having to go into the store). Any suggestions or just bite the bullet and go in?
thanks
thanks
Disclaimer: I do not have a 4Runner.
What I would do is try to
a) remove the pairing from the vehicle (reset to factory or whatever command you have to give it)
b) remove the profile from the iPhone
Settings > General > Bluetooth > Name of Profile > Forget this Device
Then try to re-pair the device again. I have issues with my VW and usually that resolves them.
Also, I don't know if you have the Navigation handbook but on page 123 it describes Bluetooth. Apparently there is a bluetooth strength indicator that shows. If this is yellow then you may have a flakey BT connection. The book says this can be caused by placing the phone in a glove box or console display. The BT icon is to the left of the battery and is blue if there is an excellent connection, yellow for bad.
Though if you and your wife are placing the phone in the exact same spot this probably won't help.
Navigation Manual said:
An antenna for the Bluetoothr connec- tion is built in the display. The indica- tion of the Bluetoothr connection may turn yellow and the system may not function when you use the Bluetoothr phone in the following conditions and places.
D Yourcellularphoneishidingbehindthe display (behind the seat or in the
glove box and console box).
D Your cellular phone touches or is covered with metal materials.
Leave the Bluetoothr phone on the place where “Blue” indication is displayed.
The only other thing would be that if your wife and you are in the car at the same time, it is going to try to pair to the first one it sees. It may not let the other one pair without some kind of manual disconnection and reconnection. If that is the case there is no easy answer except to keep BT off on the phones until you get to the car and then turn it on for the person driving.
This doesn't sound to me like an issue with Verizon or Apple - it's something in the way the 4R is seeing the phones. Unfortunately it is going to be hard to diagnose without being there in person or finding a dealer willing to take the time to think it through and not just send you back to VZN or Apple.
Most BT systems operate the same way - they will pair with the first registered device they see. If you get to the car and your wife is not around and you have paired the phone it should work. If your wife gets to the car and then you come out later, it is going to lock to her phone.
I hope that made some kind of sense. I have no relevant passages to point to regarding this in the Navi manual. (p. 231 comes the closest).
D Selecting a Bluetoothr phone
In case you register more than one Bluetoothr phone, you need to choose a favorite one.
You can select the Bluetoothr phone from a maximum of 4 numbers.
“(add new)” is displayed when you have not registered a Bluetoothr phone yet.
Although you can register up to 4 Bluetoothr phones in the system, only one Bluetoothr phone can function at a time.
Solution Found
Some how my iPhone got the TTY setting turned on. Didn't know what this was, but a strange icon on top of the phone was there (next to the BT icon). Looked like a phone with a keyboard under it. I guess this setting is for deaf people. Well, I couldn't get it turned off, so I had to reset phone and start all over (reactivate phone itself and all setting). But....the phone now paired without troubles and works great.
Thanks for everyone's help.
For future reference:
Settings > Phone > TTY [Off]
Save you the trouble of a reinstall.
Unfortunately that button was frozen and wouldn't respond (seems to be a bug on the phone, lots of posts on an iphone forum about it). Since it wouldn't turn off, had to re-set phone. All worked out, now handsfree and loving it :)
4runner NAVI is the same as Prius. How did you guys transfer phone book?? I could do everything else with my Iphone 4s (e.g. BT audio and phone calls)...but cannot find a way to transfer my contacts over to the NAVI.
As far as we've discussed thus far, I think the verdict is you can't. You have to manually move the contacts over.
phisfunk
