iPhone 4S
JS5thGen
I recently switched to iPhone 4S and while the caller id works on the iPhone it does not work on my Nav display.
Any ideas or fixes?
Thanks!
Any ideas or fixes?
Thanks!
I had to remove the "1" from my caller id records on the phone itself. (Contacts). Once I did that, I wiped the address book in the NAV and re-transferred it. All my contacts are now coming up on both phone/nav at the same time. (Correct caller id).
My address book does not have any "1" prefixes...the only time I get a "1" prefix on an incoming call is in the 4runner.
I'll have to do some more checking, I don't remember having to change any other option to make it work but it's been a long time. I'm not sure why it would be showing as "1-xxx-xxx-xxxx" on your NAV when the contact doesn't show it that way. I was almost certain this would work for you, since it's what I had to do and I had the same exact issue. I can tell you that I'm on IOS 5.01 (I haven't updated to 5.1 yet, because I'm jailbroken). I'm also on a 3GS (I'm waiting on the new iPhone to come out this year). I'll do some more digging in my NAV and see if there was another option, I don't recall seeing anything else off hand but I'll check it out and get back to you.
EDIT: Updated. *
I went out to the truck and looked at every NAV option phone related. I checked speed dials, address book, settings, etc. I found nothing to indicate the "1". I'm not sure if your phone is another carrier, I'm on AT&T. I also looked thru my phone, and I can find no settings in there that would cause contacts to pre-fix with a 1. Sorry man, i've exhausted all options here. I don't see any reason it shouldn't work for you. Perhaps it's a bug in the 4s? I don't know, as I don't own one or have one to test with. I did find an interesting read on apple's site for you - > https://discussions.apple.com/thread/3388685?start=0&tstart=0
Good luck man.
I had something similar. My 4s phone initially was synching with my address book just fine until about a week ago when I updated the OS. After that, I noticed my address book, speed dials and caller ID wasn't working. I thought maybe the OS update erased it. I've tried tonre-synch several times, butnitndoesnt seem to want to take. Maybe someone smarter than me has an idea.
