Is it safe to remove this bolt on my engine?
ArmArak
Hey guys,
I’m trying to install my York 210 compressor for OBA. I want the mounting bracket to utilize this bolt on the engine. I am scared to unbolt it because I don’t know what it’s connected to on the inside. Is it safe to remove and use for mounting?
To recall, it's one of 5 or 6 bolts/nuts on studs that holds the fan bearing housing to the block, but nothing behind housing.
The bolt you’re referring to is for the fan bracket; and is just a through bolt.
Nothing behind it
jisoo200
