Is suspension upgrade recommended for a CBI aluminum front bumper ?
MrGainzz
What’s your thoughts on whether I should get a suspension lift kit or keep the stock suspension which is strong enough to handle the weight of the bumper ?
Any inputs will be greatly appreciated!
Are you throwing a winch in there? If yes then you should likely go down the front bumper suspension upgrade rabbit hole as you are still going to be adding over 100lbs (even with synthetic line) to the very front nose of your vehicle. Lots of people complain about nose-dive with stock suspension with no added weight, this will compound it. Now you don’t necessarily need a lift but you would need a higher spring rate...which if you are changing the springs you might as well upgrade the shocks...and welcome to the $ rabbit hole.
Thank you,Chris! I’m not throwing a winch as the main purpose of this bumper is to protect the front end from getting fender bender in the city and deers maybe.
You are right ,mods are endless once you start the journey. I never thought about doing any modifications on my limited but after seeing so many sick rigs on this forum and figuring out my intended uses,I decided to make some change.
Jhunt
