is this true, fj rear 5100 on 3d gen
kolelt
Sonoransteel said, that the long travel bilsteins rear 5100 for the 3rd gen 4runners are actually 5100 rear for fj cruiser 3gen and 4th gen if I understood right. Does any one know this for sure ? If so can any tell me which year shocks would fit or the actual part number as you can find then cheaper then toytec !!
I don't really understand why those are better.
Do you think they will have more flex then my LC shocks and LC coils? How much of that is really true?
With my SS 1.2 setup I can flex the rear all the way to the bumpstops without worry. I've done it many times.
BTW, I do like Bilstiens - I'm running them in the front.
I don't know if they are "better" I'm just picky lol. I want bilsteins all around. But what is tricky is this, can anyone tell me if fb cruiser rear bilstein 5100 are the same as the so called long travel bilstein 5100 for our 4runner and the only difference is the price tag.
I hope it ain't a secret. I just called toytec and the guy confirmed it that they are indeed the same exact shocks. Even same eye size. Only difference is few bushing on too. Which I doubt it has anything to do with mounting it. So do you guys think if I was to order them same shocks of thmotorsports , I'll be good. Can't go wrong with 80$ a pop
I can't comment on the fit, but I'll bet you could go over to FJCruiserforums.com and go the local forum for your area and pick up a set for free. Lots of good guys over there and most of them through their rears away when they lift them.
I stole my 5100s from my 2012 tacoma, just pressed in a new bushing on the bottom using a socket and carriage bolt, instructions found on here. Ez and ride excellent (4k miles, LC springs). Just some words of encouragement.
Ha that's sweet. I believe the fj 5100 have 3/4 eye which don't require any swapping they just bolt right in. But are cheaper if you buy it for fj and use it on 4runner.
So if the rear shocks fit our 3rd gen's do the rear springs fit? How about the front coil overs? I have a FJ front and rear suspension sitting in my garage with only about 1000 miles on it. I even have rear lower control arms, front upper control arms and maybe rear upper control arms. What's the possibility of them fitting my 3rd gen?
The rear shocks are just about it. The front coil overs will definitely not work, neither will the UCAs. I have seen another member use rear 2" lift springs for an FJ on his 3rd gen. Although that's a bad idea IMO also. Those springs have a lot wider diameter and really don't seat properly.
Not the answer I was hoping for, but thank you. I was really hoping for a new cheap suspension.
Well, tundra front 5100 and fj cruiser rear 5100 around 360$ which isn't that bad for nice set of bilstein. But you will need to spend little on extras. Or talk to briansd_42, about the LC set up.
DanielShawSZ
