Looking for input specifically from people with somewhat modified 4Runners.
My dealership's service department (advisor, techs, everyone) really like to blame every issue with my 4Runner on the fact that I have 275 tires instead of 265. Mind you the vehicle is functionally stock besides that--I've done nothing to the suspension.
From the day I picked it up (3 miles on the odo), my 4Runner has pulled to the right. I've taken it in 6 or 7 times now to get the alignment fixed and every time they put up a huge fight and say they can't fix the alignment because my tires are not the stock size. When pressed to explain why a tire that's less than 2% larger would result in something that can't be aligned, they unsurprisingly can't explain why.
They finally fixed the alignment about 2 months ago, but in doing so managed to somehow set the steering wheel's center position to be about 5˚ to the left meaning if I'm driving straight on a flat road my steering wheel is slightly to the left.
I took it in yesterday and asked them to fix it and they again blamed it on the tires, then told me that they could either fix the alignment or zero the steering wheel, but not both. I pressed them on that and they begrudgingly fixed the issue, although it's still about 2˚ to the left, which I'm just going to deal with.
I've also had the 55-60mph steering wheel vibration issue which they refuse to diagnose until I switch back to 265 tires. It stopped doing it for a couple of months, but has recently started up again. This one is somewhat understandable.
Prior to this, I had a strange rattling coming from the blower motor that I took it in for. Despite me explaining to them that it happens even when the vehicle is stopped, they tried to blame it on the tires.
The next time I have an issue I'm going to take it to a different dealer, but this level of service leaves a lot to be desired. Curious to see if this is a dealer-specific issue or if Toyota dealers tend to do this with modified 4Runners (even if it's just slightly bigger tires).
Cliff notes: service department tries to blame any and all issues I have on my 275 tires.
