jack mount for Prinsu roof rack
Dorobuta
Well, I've begun working on my jack mount for my Prinsu rack. Started with this:
just got these (7075 aluminum, 1/2: thick):
next is to add a small piece of angle on the back side (to the holes above the notch) and then that will bolt down on top of a cross bar, and the holes to the sides of the notch will bolt to the rack frame.
these sit on top of the cross bar, and are bolted to the rack frame and to the cross bar itself.
a bolt will be added to the section above the large cut out to hold the jack.
then it will be painted (plastic-dip) black.
Hell I just used a couple u-bolts around the rails and up through the holes in the hi-lift and threw a couple wing nuts on to hold them down. Cost me 5 bucks in parts. Good job on the creativity though, I'm obviously not that talented or have the equipment to create my own mounts.
kimyuseung77
