Jaw-dropping repair estimates
Hard to see the back half of the upper control arm but other than someone spraying something near the front bushing they seem to look fine. Not really even that rusty. Can't see much of the LCA but also probably fine. These just aren't parts that really need replaced. Bushings may wear out. I've never had to replace the UCA and LCA on a Toyota (or the bushings). I replaced the upper ball joints on a 300k Sequoia and realized after I had them popped free from the UCA, the UBJ's were almost as tight as the brand new ones I had ready to replace them with.
Do yourself a favor and don't ever let whatever shop quoted you all that stuff touch your car again.
I’ll get a better pic and the LCAs but I think you’re right. The bushings look tired but the CAs themselves appear to be good. Isn’t about the same amount of work to replace the bushings as it would be to replace the CAs?
My advise is go to a parts store and get a needle grease fitting for the end of the grease gun. Poke a hole in each rubber boot and put some grease in each ball joint, tie rod etc. It will make a huge difference.
The fittings are between $3-5.00.
This is what it looks like:
Google Image Result
Haha now this I can do! What type of grease do you recommend?
If there is no play in that ball joint they look okay. Enough for a DD anyways.
Only other reason to replace them is if the inside bushings are worn and an alignment is off.
Thanks. I’ll make sure to check for any play. The o my thing that looks bad is the bushings but I’m no expert.
Toyota specifies unique greases for the inner and outer cvs, and you can go this route, but in my experience you can use a grease specified for CVs, such as NLGI#2. I use redline CV-2 on my Runner, GMC dmax and other vehicles.
Also with the needle grease injector, you can remove the small clamp and slip it under the boot to inject without puncturing the boot. Depending on what you want to do, you could remove the boot clamps and get the old stuff out, put new worm drive clamps on, then inject. Not a bad way to go if the boots are still in working order.
pretty sure hes just considering greasing the ball joints & tie rods etc with the needle, no mention of doing or needing to do CV boots.
[MENTION=664173]Toystory2[/MENTION] for the ball joints etc any normal chassis grease will work, dont need to use a special CV boot grease for the suspension components. & looking at the pics, the CA busings dont look too bad at all, i dont see any major cracking or dry rotting, not sure what is sprayed on them or why, but IMO the arms & bushings have a lot of life left in them... the old saying of " if it ain't broke dont fix it" applies here.
& as mentioned above, dont ever go back to that shop or pay those kinds of prices for what is pretty basic work... shops/owners like that should be shut down & arrested for theft! if you were a women or guy that didnt know better they would rob you blind & thats what they do to unknowing customers on a daily basis! & dealerships are just as bad or worse.
[MENTION=664173]Toystory2[/MENTION] for the ball joints etc any normal chassis grease will work, dont need to use a special CV boot grease for the suspension components. & looking at the pics, the CA busings dont look too bad at all, i dont see any major cracking or dry rotting, not sure what is sprayed on them or why, but IMO the arms & bushings have a lot of life left in them... the old saying of " if it ain't roke dont fix it" applies here.
Thank you for the tip. I’m definitely going to try this. Do you think it could stop the clunking I hear when driving over a bump?
I appreciate the recommendation. I’ve never been one to do PM on the suspension (mainly because I didn’t know better). But I’m gonna start now and try to stave off any issues for a while.
unfortunately no, greasing suspension parts wont fix a loose or worn part that causes clunking... as mentioned thats usually shock related or worn out & sloppy parts like BJ's or ushings etc.
based on the pics that dont show the full bushing & cant determine if the bj's are bad or not, i would guess its the shocks or other suspension part. there is a pretty simple procedure to check the bj's, youtube should show it or check a repair manual.
another things to look at that hasnt been mentioned for clunking noise over bumps is the front sway bar to frame bushing, not the end links, the bushings will eventually wear & allow the sway bar to touch the frame & cause a clunking noise.... had that happen on my old jeep cherokee & on my 08 4runner, quick cheap & easy change & going to poly bushings will stiffen up the handling on corners some too. check for any play or slop on the sway bar or visible signs of the bushings being worn or the hole wallowed out.
Clunking over bumps is usually from blown shocks/struts or sway bar links.
The mechanic indicated that all struts and shocks are worn and need replacing. It’s still running the originals from the factory. I’ve done shocks in the past so I feel decent about being able to do it.
I’ll get some good pics that show everything. And thank you for the sway bar recommendation, adding that to the list!
4runners dont have struts... i hope the shop/mechanic that told you that is just using generic terms for the front coil over shocks.
the shocks on these 4runners are pretty easy to replace, download the service manual posted on here somehwere or watch some youtube videos.
aside from the front shock possibly being rusted in the top tower & needing some prying to break it free, the rest of the procedure is very straight forward... reason why the prices quoted from that shop are ridiculously outrageous.
The report they sent me actually says front struts and rear shocks. After I looked the other day, I was thinking they looked an awful lot like shocks. I can do this!
Air hammer is really nice for getting the top shock mounts out of the coil bucket if they're really stuck
4runners dont have struts...{snippage}.
You keep saying this, but Toyota along with every aftermarket supplier of front suspension parts calls them struts. As far as I can tell, our front suspensions meets the description of a Macpherson strut per the Wiki.
The BMWs, Hondas, VWs, Subarus, Mazdaa, and Hyundais I also maintain call the same arrangement of a weight bearing spring seat on the shock body with a rotating upper mount point a strut as well.
Please enlighten me (us) on why the 4Runner does not have struts.
Its a coil over shock assembly in a double wishbone suspension. On the BMWs I own, the struts are a cartridge in a housing with control and thrust arms. I cant recall any production model BMW that used a double wishbone, aside from the M1 which was produced for homologation.
I mean this with absolutely 0 offense to any one who doesnt have the means to do their own work, but holy hell... seeing stuff like this makes me so glad I've been fortunate enough ( or not? lol) to be able to tackle just about any mechanical project needed on any of the cars.. There is absolutely no way in hell I would be able to have any of my vehicles at the stage they are now if I had to pay even half of those labor prices..
I also have absolutely 0 trust in anything any shop tells me is a necessary repair (this one is from a multitude of absolutely terrible experiences over the course of my car ownership). There are literally a handful of people I can count on one hand that I would blindly trust the recommendation on what needs to be done on my cars.
i keep saying it because its true. the definition of a strut vs a shock clearly describes the difference, struts are part of the steering axis & dont have an upper control arm. shocks/coil over shocks dont have any rotating points related to steering & have upper & lower arms. but here is a pic to show it better.
regardless of what aftermarket companies or some mechanics call them, 4runners do not have struts, they have coil over shocks in the front with upper & lower ball joints in the 2 control arms & do not rotate.
hope that enlightens you
please enlighten me (us) where toyota calls 4th gen 4runner front shocks, struts??
when buying new shocks from toyota they are called shocks. & in the repair manual they are called shocks, no mention of these being called struts on 4runners.
not sure why people are so confused on the proper terminology of shocks vs struts... probably comes from aftermarket companies & mechanics using generic terms, but if you hold a shock or coil over shock in one hand & a strut in the other its very obvious how/why they are different.
my apologies for correcting people when they call them struts, i have this crazy affliction where i like to provide accurate info in an attempt to help others... & i appreciate it when others help or correct me when im wrong. :peace:
Mike Sargent
