JBL NAV - Daylight Savings Time
boneill
I have a 2013 4Runner Limited with the JBL Nav System. The Nav system time seems to be off an hour. Under settings it is set for automatic daylight savings.
Does anyone else have this issue? Any ideas other than wait it out? <smile>
Thank you
Brendan
OK, seriously, try turning that auto-DST off and manually setting the time.
I don't recall that setting on my JBL Nav, and have always set the time manually. Did they change the JBL system from 2011 to 2013?
I have a '13 Trail (with NAV and Entune if that matters) and was able to adjust out of Daylight Saving Time. As I recall there are two buttons to the left of the time that say "Mode" and "Set" with an up arrow on one, and down arrow on the other.
I can't remember how it worked but I found the directions in the manual. You just hit the up or down button as to whether you want the clock to go forward or backward in time. Then I can't remember exactly what made the clock move, but it did.
Sorry I don't have time to look this up again, but hopefully my starting info will get you to where you can figure it out.
Good luck !
