Jicko Build Thread ...
Gobi Rack/Ladder Installation
It's time to call up the crew for a Gobi installation party!
With some young, tall and experienced help, it is pretty simple to get both the rack and the ladder on!
And in the process, taking over my street with a 5th gen 4Runner convoy!
Still waiting to get the Rigid Lights onto the Rack.
Also, decorating the inside with some morale patches:
Special thanks to [MENTION=117606]BeachRunnerSD[/MENTION] and [MENTION=126173]SKP-4R[/MENTION]!!
Rigid lights installed, they look AWESOME!
Oh, another installation tips.....
Use a 6" strip of clear bra (protective film) on the roof where the Gobi fairing/wind-deflector touches the roof. This will eliminate dust/dirt that stuck under there and eventually grinds and hurts your paint.
You can order that strip here: http://amzn.to/1Mxwfiu (the best quality, 3M ones)
Or you can try to find similar ones @ your local auto store.
Steps to apply:
1) Clean the section of your roof that you are going to put this on
2) Cut the strip to approx. length
3) Get a bucket of soapy water, soak strip in it, and detach the "white" backing paper in the water
4) Lay that "clear noodle", sticky side down (with the soapy water, it is not that sticky, and that's the goal), and move it around to get it in the right place
5) Push out all the air bubbles underneath the strip while it is still wet
6) Let it dry for a little bit, now the sticky side should become a lot more sticky
7) Trim off excess with a scissor or a exacto knife
I think it's time for a visit to ICON
Its about time.....
So i guess its time for the TRD Pro Grille Group Buy?
Tried that, no love...... none of the Toyota dealers are interested/willing to do group buys......
I was thinking these will make good GB items:
- TRD wheels
- TRD grille
- TRD skid plate
But.... answer was no.... they think that they can move the parts at full price.... no motivations on GB....
I don't blame them. People will buy anything for retail if it has the holy words "TRD" written on it. the TRD Oil caps are proof of that.
Odyssey 31M-PC2150 "Trolling Thunder" Deep Cycle Battery Installation
I had looked into various battery strategies (single, dual), and considering my use case, I have decided to start with a single large capacity, deep cycle battery. As it is much simpler, easier, and lower cost to implement than a full-on dual batteries with isolator setup is.
My use case:
- weekend and short(few days) offroading trips
- driving around during the days, and camping during the nights
- maximum "offline" (car's engine not ON) time will be no longer than 36hours
- powering (offline) ARB 50QT fridge
- powering (offline) HAM mobile radio
- powering (offline) some low power LED light strips
Like many others on this forum, I have decided to use a 31M-PC2150 marine grade, deep cycle battery, from Odyssey (some claimed that Sear's Diehard Platinum 31M is the same thing).
Amazon.com: Odyssey 31M-PC2150ST-M TROLLING Thunder Marine Dual Purpose Battery: Automotive
SPECIFICATIONS
Pulse (5-second) Hot Cranking Amps (PHCA): 2150
Cold Cranking Amps (CCA): 1150
20Hr Nominal Capacity (Ah): 100
Reserve Capacity Minutes: 205
Dimensions L x W x H (in): 13.00 X 6.80 X 9.41
Weight (lbs): 77.8
Some useful info about this particular battery (voltage vs % of charge):
This battery comes with brass SAE posts, 3/8 inch positive and 5/16 inch negative thread SS stud terminals. And in order to it to hook up to the "factory" clamps without ANY modifications, ordering some Remy Battery "Stud to Post" converter is THE WAY TO GO! (Be sure to order 1 of each size) Stud to Post Conversion Adapters - Remy Battery
Also, while you are ordering from Remy, I found that their group 31 battery to be the lowest cost solution ($8.44!!!) to house the battery (a $100 battery cage is NOT needed!!): Steel Battery Tray (13") - Remy Battery
Post converters screwed in (and extra converters) and the battery tray:
Size comparison between the Odyssey 31M vs the stock Panasonic:
Once you removed the factory battery and the whimpy plastic tray, the new steel tray fits right in, and you can get a "M6 bolt/screw" (maybe 15mm long) and a washer to screw into a threaded hole as you can see in the picture below. Together with an aligned "hook", this tray is not going anywhere!
Unfortunately, with the added battery try, the factory "J-hooks" are not long enough to hold-down the battery, you would need some 10in hooks. You can get them from Amazon cheaply (with prime too): http://amzn.to/1PHfrFm
I am not a big fan of the "wing nut", hence, I dropped into home depot and picked up some 1/4" (IIRC) nut/washer/lock-washer for the "J-hooks". And 1 last final touch (not really necessary), is to use a bolt-cutter and trim off the extra length of the J-hook that is closer to the fuse box).
Here it is, all mounted!
SOLID and economical!!
How long did the swap take?
If you acquire all those little things listed in my post before your start the swap, the swap itself will take you like..... 15min? Everything is plug and play, fits perfectly, no wire re-routing or metal bending needed. And extra pair of hands to help lift the 75lb battery and set that in place will help tho.
Double check the nut/washer/locking-washer size by bringing the J-hook to home depot will help too.
Excellent. I was thinking of doing the same swap.
Looks great. I'm going to go with the same setup. Thanks for the all the info. Was Amazon the cheapest you were able to find the battery?
Not really, but if there is any issue, Amazon will help you mitigate it, and they will pay for return shipping too. As this is an HEAVY item, I think it is worth it to go thru Amazon.
RCI Metalworks - TRD Skid Integration Plate Installed!
I want RCI's skids to protect my underbody, but I love my TRD front skid too much...... what can I do?
Thanks to Josh & RCI Metalworks, here is their solution for us!
14+ Toyota 4-Runner TRD Integration (Filler) Skid Plate
This piece of art is SUPER well made, with 1/4" aluminum (same thickness of aluminum as the TRD front skid), protecting the low hanging front differential and oil pan. (They do have a 3/16" steel version, but I chose the 1/4" aluminum for its weight benefit)
The factory front differential & oil pan skid is a joke. Yet I guess, if you have the regular factory front skid, you would damage that (and you probably would have stopped) before you hit this piece. But, if you do have the TRD Pro/TRD front skid, a rock can easily slide off the TRD skid and land on this thin, whimpy sheet metal and cause a big issue.
One of the nicest thing about the aluminum version is that it is not much heavier that that whimpy factory skid! The factory one weighted in ~7lb, while the ultra strong RCI's AL version weighted in only ~9lb!!
Some other worthy to note features:
- welded bolt protection rings for bolt protection
- access port for the oil pan (adding a Fumoto valve maybe good)
- the front plate edge sits about 1/8" lower than the TRD skid, so there is no bad edge to catch
- aluminum will not rust, no painting/rustoleum needed
- the whole installation took me like 15minutes only, everything just plug and play; I didn't even have to jack up the car
- seamless integration with other RCI skids; their transmission skid will slide underneath and behind this and bolt to the same 2 bolts, and their transfer-case skid will follows too.
IMO, if you have a TRD Pro or have a TRD Front Skid, you'd WANT this TRD Integration (Filler) Skid Plate!
:cheers:
** RCI GB upcoming.... LOL **
http://www.toyota-4runner.org/group-buys/205276-rci-metalworks-*group-buy*-fall-2015-a.html
Awesome stuff you have done.
Any chance we can get a shot of those DRL Leds in daylight? I also didn't see if you followed up about the regular DRLs having to remain on or not when active. I would assume not since these have their own button.
I am debating on new fogs and these were the ones I been eyeballing but haven't really seen any good shots of them on peoples vehicles.
Thanks!
This is a great thread, thanks for all the detail. I'm sad to say that work now blocks the pictures after your June 27th update so I'll have to actually get stuff done and browse at home now haha
Crookedcat
