Thai
Elite Member
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was included in the product brochure.
In addition, Wife 1.0 installs itself into all other programs and launches during system initialization, where it monitors all other system activity. Applications such as Pokernight 10.3, Pub Night 2.5, Weekend Golf 6.1 and Football 5.0 no longer run, crashing the system whenever selected.
In addition, applications such as Rubbish Out 3.3 and Garden Work 2.1 have gone from select-as-needed to continuous schedule. Ignoring them causes Night-on-the-Couch 1.0 to take over all activity. I cannot seem to keep Wife 1.0 in the background while attempting to run some of my other favourite applications.
I am thinking about going back to Girlfriend 7.0, but the uninstall does not work on this program.
Can you help me, please!!
Thanks,
A TROUBLED USER
REPLY:
Dear TROUBLED USER:
This is a very common complaint which is mostly due to a primary misconception. Many people upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0 is merely a UTILITIES & ENTERTAINMENT program.
Wife 1.0 is an OPERATING SYSTEM and was designed by its creator to run everything. It is unlikely you would be able to purge Wife 1.0 and still convert back to Girlfriend 7.0. Hidden operating files within your system would cause Girlfriend 7.0 to emulate Wife 1.0 so nothing is gained.
It is impossible to uninstall, delete, or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more problems than the original system.
Look in your manual under"Warnings -Alimony/Child Support".
I recommend you keep Wife 1.0 and just deal with the situation. I suggest installing background application program C:\YES DEAR to alleviate software augmentation.
Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding General Partnership Faults (GPFs). You must assume all responsibility for faults and problems that might occur, regardless of their cause. The best course of action will be to enter the command C:\APOLOGIZE.In any case avoid excessive use of YES DEAR because ultimately you will have to give the APOLOGIZE command before the operating system will return to normal. The system will run smoothly as long as you take the blame for all the GPFs.
Wife 1.0 is a great program, but very high maintenance. Consider buying additional software to improve the performance of Wife 1.0. I recommend Flowers 2.1 and Diamonds 5.0. Do not, under any circumstances, install Secretary With Short Skirt 3.3. This is not a supported application for Wife 1.0 and is likely to cause irreversible damage to the operating system.
Best of luck.
Tech Support
Thanks,
A TROUBLED USER
REPLY:
Dear TROUBLED USER:
Best of luck.
Tech Support
